I have been converting my 32 to as many LED globes as will fit. I purchased some amber LEDs for the rear indicators (BA15S, 1156), but they caused to indicators to rapid flash (like when a globe somewhere is blown). I then purchased some advertised as CANBUS-compatible, but they also rapid flash.
Is there a way to confirm if the LED is in fact CANBUS-compatible (construction, watts, multimeter, etc)?
https://www.sau.com.au/forums/topic/478851-canbus/
You can try to find a flasher relay that's "LED compatible", or run load resistors (half defeats the purpose IMO).
I got some Philips resistors if you're interested (I bought TapTurn relay).
CANbus is for newer cars that would throw an error light if a bulb was out.
https://www.sau.com.au/forums/topic/478851-canbus/#findComment-7917685
https://automotivesuperstore.com.au/aerpro-ledres
https://www.sau.com.au/forums/topic/478851-canbus/#findComment-7917761
  • 8 months later...
Further to my problem, I have done the same to my N16Pulsar. I got some "canbus" LEDs, fitted one to the front left, and everything works fine. So then replaced the right side, and it hyper flashes! WTF!
Anyone got an explanation?
https://www.sau.com.au/forums/topic/478851-canbus/#findComment-7933415
Yes, finally resolved myself to the need to modify the system. Only ever purchased units "guaranteed" not to hyperflash. Jaycar have flasher units, FYI.
So, where is the flasher can in aR32? Anyone know where the can is in a N16 Pulsar (1.8DE)?
https://www.sau.com.au/forums/topic/478851-canbus/#findComment-7933821
I am sooooo glad Nissan make these cars so easy to work on and replace parts that break down.
Pretty much pulled the entire instrument panel apart, cannot for the life of me locate the relay (can hear it, just can't find it!).
https://www.sau.com.au/forums/topic/478851-canbus/#findComment-7933857
Well, I've solved one problem - when I arm / disarm the alarm, only the LH indicators flash. Found the (smashed) fuse, and replaced it.
But now I have a bigger problem - NO indicators OR hazards! So I know the return circuits are ok, because the lights come on with the alarm arm /disarm. But because I have no hazards  /indicators, I can't trace the relay sound.
https://www.sau.com.au/forums/topic/478851-canbus/#findComment-7934005
All solved.
Reason everything suddenly stopped - I somehow unplugged the connector to the back of the hazard switch!
Indicators work fine with a replacement flasher designed for LEDs - SY4018, $14.95 from Jaycar Electronics. (in the "auto" section, not the electronic parts section)
https://www.sau.com.au/forums/topic/478851-canbus/#findComment-7934299
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
