1 hour ago, Dil-Dog said:
Just make sure that you get a PULL type clutch
why ? push clutches dominate the market, available in many more configurations, and are more practical to actually work on. Yes it does require a conversion in a 93 - 94 R32/,R33/R34 GTR situation but it seems like you are inferring that pull is better than push.
I fully converted my R33 GTR away from pull to push for this reason for more clutch options, and no not the OS giken pull to push arrangement which still uses pull slave and line. On my R33 GTR I did full R32 GTR 11/16" push slave cylinder, push gearbox front cover, uprated cast alloy Z33/Z34 instead of pressed steel clutch bearing release fork, chromoly fork pivot (not the Nismo reinforced push pivot) and braided reservoir to clutch slave line deleting all that hard line bullshit that Nissan uses to the slave cylinder. End result is gold, actually works properly and reliably.
2 hours ago, Baroque said:
-Im looking ONLY for NON RATTLE situation(especially on idle)
Have you actually read anything I've said ? Any idle noise from the Getrag box is going to come down to your flywheel being dual mass or single mass, not the clutch plate count or what the plates are made of. I have given you the pros and cons of each flywheel type. You still haven't outlined a power figure which is actually important in this part selection. Is it stock, 300, 400kw at wheels ect. It determines what you need or should use.
Sorry but I'm out. Any GTR is not a refined, smooth and silent type of car like you are trying to make it out to be. I wish you the best of luck and I hope I've been a help to some degree.
I suggest you give a clutch specialist like Australian Clutch Services or NPC a call for any further info to help you.
I dunno about you but I find the Skyline GT-Rs to be surprisingly refined. With the R34 they were definitely trying to go for more refinement, easier to drive, etc. The R35 only continues the trend. If anything the R35's native NVH is a little worse because of the V6, they just muffle and dampen everything to be what you expect from a modern car.
I would say if OP is really, really obsessed with getting as little noise as possible the only choice is to use a new OEM dual mass flywheel and an upgraded single plate like mentioned in this thread. If he's willing to compromise a little with the dual plate chatter then ATS silent twin plate. If he's ok with some of this noise then Coppermix twin or ATS twin plate. This is the stuff we're talking about though:
In my situation,i could use single plate because of the soft and sensible style of drive I prefer . If this car with single plate would be used by a guy who need high rpms,reving,launch control all the time and burnout lovers,of course it would crack to the lil pieces in a week.Yesterday i did some new calculations what the project is gonna be in power matter.Stock r34 clutch,as i heard,holds up to around 500-550 hp.Primary I estimated my power for 550-570hp.So i knew i could use aftermarket single,but as I wrote,twin would be better if I could solve the rattle problem. After second calculation that i said above it will be 600-650hp so now i know exactly,that i need twin plate.
Its not a obsession joshua.I just want to be one,unique son of a *itch who could cope with that problem the best way possible,even if it takes to spend huge amount of money.Thats the respect i give to this car lets say. .Everything to the perfection.
I wanted to say earlier of course,one and unique if no one ever did this the best way possible,because if so,i will be next,but as i saw on the internet,people are giving up and accepting that con of multiplate.I have will for 10 years now,and money to do perfect project,so don't judge me for that,and my detailed needs..If the rattle cannot be solved totally,im talking of course about lowering the noise to the minimum.However i cannot help myself in 100% because its not my knowledge field,thats why choose you guys to help me,what to do.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
