What do you mean "conversion"? Are you talking about using original panels? You do realise that the R32 and the R34 are completely different shapes, right? You won't be able to stitch the rather vertical sided guards of the 34 onto the somewhat more curvy rear half of the R32 guards.
Any such conversion you have seen done before (like the S15 onto S13 strawberry face conversion) involves complete replacement panels in fibreglass. Not steel stitched to steel.
I'm not saying it is impossible, but it is not something you just "do". This would be a massive custom bodybuilding exercise to be undertaken by a skilled panelbeater.
Most likely using the rear half of the r32 fender and blending the r34 front half to it but that’s why I’m asking... If I have to make a custom fiberglass fenders that’s not a issue. Thanks for the input but I’m looking for actual experience on the topic. I get that it could be a little bit more work than a r32 core support replacement and that’s no problem either. I have time.
So, did you search? More than 20 years of actual stuff on this forum alone.
viz.
Most of these use plastic.
https://www.google.com.au/search?q=r32+with+r34+front&tbm=isch&source=univ&sa=X&ved=2ahUKEwjkuNjK6PLmAhUFxzgGHRi9CcYQsAR6BAgGEAE&biw=1779&bih=888
Edited by GTSBoy
viz.
Yes most are a dead end or not the way I’m doing this conversion.
Edited by Chris D
14 minutes ago, niZmO_Man said:
Bee*R did it like a decade ago.
https://www.rhdjapan.com/bee-r-b324r-full-swap-kit-skyline-r32.htm
What's so special about your project? You want to blend the two panels together? Cool. Let us know how you go.
Yes they did but they used the r32 core support.
Which suspension do you propose to use? The upper arm mounts to the inner guard are totally different between 32 and 34. If you're talking about using 34 radiator support panel, then it only makes sense to use the inners as well. And then you're forced to use 34 suspension. Not that that's a bad thing, as it is much better than the 32. But you're talking about major surgery of both the inners and outers.
I don’t plan on messing with any of that. I’m gonna swap on the 32 core support with the 34. I’m sure there will be some fab work to get it on.  I only have the front nose not the whole front clip.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
