Hi guys
have done some serious work to my engine atm:
2.9L stoker kit
Neo ultimate head
Tomei 260 camshafts
Yellow jacket coil pack
otaku garage forward facing intake plenuim with a 90mm throttle body
and I’m not even on my L plates yet
thats why I’m doing all this work so when I get my p’s I can do an actual gtt turbo not a plus t setup
so if anyone has suggestions on what I’m doing and what I could do better please let me know
but back to my main question
can you convert the internals of a gt gearbox to a gtt
ive heard there the same just internally different but want to be sure
and should I be upgrading diff and drive shaft
thanks jack
No. The NA gearbox is physically much smaller. Like half the size.
You don't need to upgrade either the diff or driveshafts. Not for strength reasons anyway, as the diff is the same strength as the turbo item and the axles are nearly as good. But.....you will want an LSD centre on a turbo.
Note that I said driveshafts. You said driveshaft, and it is not clear whether you meant the tailshaft or the axles. Not that it matters, as both are strong enough.
It's also not clear what the stroker kit and other parts are fitted to. The NA engine? A turbo engine in the shed? If you've done it to the NA, complete waste of time. If you've done it to the turbo, well, the yellowjackets are not a good choice, but beyond that, everything else is OK, if largely a waste of money.
You will need brakes. And, are you sure that you will be allowed to drive a turbo on your P's?
Hi mate
yeah meant driveshafts sorry typo
and the n/a block is exactly the same as the turbo
And do you know what ignition coils I should run
im using the n/a block as it’s the same as a det but am putting det head on top
49 minutes ago, Jacks red r34 gtt said:
Hi guys
perfect example of why not to fit that style of plenum. lost 1000rpm of response and a bucket load of power. Green is factory plenum, the others are a short runner style plenum. Bin the yellow jacket coils and get a PRP r35 coil kit.
  • Like 1
Ok thanks
just wish the stock didn’t go over the valve covers
looks ugly and is really inconvenient when working on your engine
and do r35 coils stick out of cover?
13 minutes ago, Jacks red r34 gtt said:
Ok thanks
It's really not hard at all to remove the crossover pipe as required, which is not often.
Get split fires if you want it to all fit factory. You will have trouble with yellow jackets
  • Like 1
But look at the peak gain! And how much cleaner the engine bay looks.
  • Like 1
17 minutes ago, Jacks red r34 gtt said:
Btw could you link the coil kit
cant find it
http://letmegooglethat.com/?q=Prp+Rb+coil+kit
I don't like the look of most of those plenums and fitting the new plazmaman ones with engine in is a pain with the water hose/pipe underneath.
  • Like 1
No its NOT mate, no piston oilers for a start, and past experience of these blocks found that the turbo oil supply gallery has not been drilled either, or the turbo oil drain hole as well.
Edited by Rusty Nuts
Ok lol
lucky i haven’t installed anything yet
does anyone know if you can run the det neo engine without the turbo using parts of a device engine?
1 hour ago, Rusty Nuts said:
What the hell is that???????????
It's what happens when you exclusively access the internet on a phone, type "de" and have the stupid device (the phone) think you were talking about it and autocorrect to "device".
  • Haha 2
And just so everyone knows I’m not dumb it’s just I made a sau acct less than a day ago so am still learning
and robbo I thought you meant put r35 coils in a rb
that’s why I got confused
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
    • I spotted a black C34 in Mittagong this morning!
