On 9/3/2022 at 1:39 PM, Dose Pipe Sutututu said:
I'm still wondering if Xtreme GT-R is using a RB25 NEO head OR just adapted a NEO VCT to a RB26 head.
Custom VCT to RB26 head 👍
  • Like 1
  • 2 months later...
Nothing to specifically update here, but just putting k's on car and it's been flawless. The turbo elbow hose failure has been about the only recent issue with the car. I'm still running a silicone replacement until I can be bothered to pull the turbo compressor off and weld a proper cast alloy elbow on for a permanent fix.
Apart from that - no complaints. Still love the 2.8 / 6466 combo, the PAR box has so far proven to be very good and couldn't be happier with the entire engine management side using the current fuel system and Ross crank trigger setup all controlled from the Elitec 2500. The Ross trigger with the GT101 hall effect sensors I absolutely rate 10/10, unlike the heap of shit NZ wiring cam trigger on the white 32. I will elaborate on that later, but they are no replacement for a real crank trigger setup.
Found a few pics from when I was moving away from the Bosch 044s to the AEM setup with upgraded 10mm2 wiring, 2 x 400lph staged externals, dual speedflow check valves and 340lph lift pump all throungh AN8 200 series lines, basically binning the existing mismatched and poorly installed Willall racing setup. I really expected better from them as their setup caused me nothing but dramas. Note the new pump power supply 10mm2 wiring in comparison to 2.5mm2 existing - big difference.
IMG_20210426_135029_5.thumb.jpg.41c9cfd97a39d80beaca173a4a75ed06.jpgIMG_20210426_160640_1.thumb.jpg.1634b2e5fd8c81d682a344f32ecd0185.jpg
Next thing on the agenda was to fit the Turbosmart OPR T40 turbo oil reg. I've been putting it off because of the fittings and stuff I had to figure out that was required for install, and I'm glad I hadn't fitted it yet. OPR T40 won't be going on, ordered 2 of these below today and will be removing the T40 from the white 32 too.
https://www.turbosmart.com/product/opr-v2-turbo-oil-pressure-regulator/
  • Like 3
Modernisation of pumps, less heat, less noise.
Yeah I'm going to rip off my v1 OPR valve too at some stage and replacing it with the V2 OPR to reduce the hose clutter!
I actually think the old T40 on the white 32 is increasing crank case pressure increasing breathing too.
Think about it - any oil pressure in excess of 40psi is being fed back into your sump pressurising it. Normally you only have your low pressure turbo oil return and block oil passages gravity feeding back to the sump. With the T40 you are adding potentially 60psi+ with a Nitto pump back into the sump - this can never be a good idea adding to crank case pressure.
Quite possibly, I agree with your theory on that one!
I probably don't see these issues with the other band aids on top (sump/head breather/drain, sump to catch can breather/drain).
White 32 has the head breather / sump vent and decent catch can setup but still retains the stock rocker cover baffles. I've always thought it breathes more since the T40 install, so will be interesting to compare. Definitely breathes more than the blue 32, which has all that mentioned above but additionally has the Mines rocker cover baffles and 2nd pre catch can acting as an oil / air separator but also doesnt have the T40.
  • Like 1
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
