1 minute ago, xmanz said:
Am i unlucky in the fact my 07 v36 at only 63,000k has done a head gasket as bubbles come up and push water out of radiator.  So is this just a thing thats happened or what may cause this?  probly looking at 2500 nz  thanx ill no go and be depressed...:)
You may be unlucky as to the fact that your clock is probably wound back if the head gasket is done at "63k"
https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7925034
Where do you live? Should be able to fix that for less than 2.5K
https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7925048
Just air bubbles? Have you considered that maybe you just have air trapped in your coolant and not a blown head gasket?
https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7925053
Agreed. If there are no obvious signs of oil mixing in with the coolant, the coolant itself needs testing first. It'll be a lot easier than what your mechanic is proposing. He's jumping the gun a bit there.
Edited by The Max
https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7925161
  • 3 weeks later...
im in napier the guy thinks upwards to 3 grand     and seems to think the engine may have to come out or drop the front away!!!
he may be reading wrong stuff..  so to do head gasket does the whole timing covers have to come off?   or can heads be done insitu....
thanx guys
Edited by xmanz
spelling
https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7926380
16 minutes ago, GTSBoy said:
Well, yeah, most of it - certainly at least the top part. The VQs are chain driven, yes? But pulling timing covers off is not the difference between affordable and not.
i got a bit lost on last part of your statement       ( But pulling timing covers off is not the difference between affordable and not.)
im trying to assertaian if the front has to drop away and take radiator out for acess   cheers
https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7926389
Do you mean remove the front of the car? Hell no. Take radiator out? Quite possibly. But that's not expensive work. Neither is removing the timing covers. That's what I meant when I said "But pulling timing covers off is not the difference between affordable and not". If it adds an hour to the job it's an extra hundred buck or so, right? Not an extra $500.
https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7926393
ok that sounds not too bad is the timing cover one piece or is there a top section thats not behind pumps and  things...
btw i had a search for v36 workshop manual  and g36 for 2007  cant locate any ideas
https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7926397
When it is all fixed I  would have the rad fan checked (I would think they are a clutch fan) blow a head gasket in our D.Max at 130K and five years old. Don,t rely on your temp guage I  ran a scanguage 11 in our Isuzus and that how I seen the temp rise, nothing showed this on the vehicles temp guage.
https://www.sau.com.au/forums/topic/479795-am-i-unlucky/#findComment-7926401
    • Here's a boring history lesson on number plates People want illegal spacing to make their plate more readable, if mine was J2X BK, anyone who knows about the car would see that its spelling JZX. Years ago third party plate manufacturers could alter the text to make it look like something else, nowadays the computer software is locks that ability (well, ours does at work) Up until 2001 the first letter of a number plate represented the year of the vehicle, for example A would be 1983. (pre 1983, the format was backwards, so the year letter was on the end). Followed by 3 random numbers and 3 random letters. Things started to get complicated at the end of the 90s where T and V were 1999, W and X were 2000 and Y was early 2001. From 2001 they introduced a new 'layout' where the first two characters are letters, this represented where that vehicle was first registered in the country. The letters corrosponded to a region in the country. Some regions had a large number of codes, where as some only had a couple (despite being large in physical land size) Next are 2 numbers to indicate 2000s. So it went from: Y (March 1999 > Aug 2000) 51 (Sept 2001 > Feb 2002) 02 (March 2002 > Aug 2002) 52 (Sept 2002 > Feb 2003) etc etc When the 2010s got here, the numbers changed again, going up by tens 10 (March 2010 > Aug 2010) 60 (Sept 2010 > Feb 2011) When the 2020s arrived it went to 20 (March 2020 > Aug 2020) 70 (Sept 2020 > Feb 2021) etc As for personalised plates, you're not allowed a registration that makes the vehicle look newer. Take my 110 for example, its a 2004 car so I can have any available plate upto 04. I can't have a 54 because it was manufactured in August 2004. Which allows me to have a J plate, because its older (if that makes sense)
    • Mount some of these on your dash? https://www.greddy.com/products/16001720
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
