Got my quote for a cam and stuff install.
Waiting for workshop time now.
oztrack-camshaft-kits-with-remote-custom-tuning-afm-delete-removal-cam-upgrade-online-leaders-in-ls-auto-part-tire_709_250x250@2x.jpg.4657e7a70c1e18cef044f9f6ef46454a.jpg
Cannot decide on which one though.
Oztrack recommend the LSV or HP3.
They recommend that LSV would suit the car as is, but the HP3 has headroom for intake manifold and head work in the future.
LSV idles smooth and comes on fairly quick.
The HP3 is fairly choppy (I love the sound of a lumpy cam) but still ok for the stock converter.
Both are a big improvement over the current cam, lots of gains in torque and between 30-50kw up high.
I'm leaning towards the HP3 maily because of #lumpyloapylols, the 3.9 diff gears should "hopefully" help it get up into the cam without to much delay.
Streetability for both are apparently good.
Hmmmm
In other news: my fears of a highstall and not locking up in the auto are unfounded, soooo, if I do go the bigger cam, a high stall converter will be the next mod.
Now all I need is that WSID opens soon so I can do a pre and post run.
LOL, f**king Covid spoiling all my fun.
Hmmmm
LSV out of those choices. THe LS1 doesnt need / beneift from such a large exhaust duration split.
choppy idle can be tuned to suit.
glad you have seen the light regarding conveters!
  • Thanks 1
You are going to run into the exact same problem I did re: Cams and the rest of the system being able to supply the air the cam wants.
Be aware!
If you are going to keep stock heads (and not be super obsessive about checking springs, etc etc, want something that will be put in and forget) then the LSV is the smart choice.
The "power" category of that chart does require additional mods to unlock the said power. Drivability is easier in an auto which you have on your side. Cam surge is just shit to live with. Power under the curve is still a thing in V8 land.
  • Thanks 1
Be aware!
I've been looking at heads and an intake, the intake is relatively cheapish, the heads are costly, sooooo
Thanks all for the information, I'll have them throw in the LSV with the all the other snot they install at the same time.
It is diminishing gains (especially value for money wise) when going further than just a cam / spring job.  As kinkstaah said area under the curve is still important, and going to a larger can will hurt economy also
  • Thanks 1
Car goes in tomorrow.
The guy recommend trunion bushing kit?
They look like solid brass vs roller.
Like this > https://vcmstore.com.au/products/ls-rocker-trunnion-upgrade-kit
Thoughts
Thoughts
Wrong part number and link for nitrous kit
  • Haha 1
Thoughts
I vote no. I would be more concerned the trunnion galling when solid, considering the way they are lubricated is "hoping the oil splashing around happens to land there", push rod style! .
  • Thanks 1
Its less choppy than mine. That said it probably drives right, and doesn't shake you and your passengers at idle in the seat (is kinda cool tho) and is the right cam! Which one did you go in the end?
LSV
It does do a "little" shimmy at idle in neutral, once in drive it just squats down a bit harder on the brake.
Thats really what you want man.. Idle shake is cool and all until you have anyone in the car that doesn't think its great and it quickly becomes shitty.
That cam looks the goods. Was the dyno run locked?
So, after taking the Mrs for a cruise today (Robertson pie shop, long way there, long way home) I'm definitely looking at those interceptor copies in silver, with caps of course, #fullbogan
17 x 8 + 42 for the front
17 x 9 + 48 for the rear
Tyres will be Hankook RS4, cheap but good.
235/45 front and 255/40 rear
Rollin' on 19" rims and rubber band tyres is arse on anything other than dead flat and smooth highways.
I'm just waiting on a shipping quote.
In other, Mrs related news, she wants me to put the pacemaker rear muffler back on, doing a dollar ten on the highway with 3.9 gears is to noisy for her to sleep.....LOL.
Meh, things you do..
I'm also still looking for 2 interceptors, 15 x 7 which I will shod with some Micky T's for LOL's at WSID.
I believe the converter was locked.
But, my speedo reading is way out now, I believe they f**ked up the calibration it had for the 3.9 diff when they played with rhe tune.
GPS reads 80, speedo reads 100.
How and if this effects anything I have no clue, apart from me driving like Miss Daisy.
I'll ring them tomorrow to get it fixed.
I was doing what I thought was 100 in a 100 zone and everyone was passing me, I got the Mrs to get google maps up and to my dismay I was doing 80.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
