Finally installed the Forsa FP2 brake pads in the front
Flushed the fluid and bedded them in
Old pads were QFM HPX
So far so good, good cold bite, good feel, seem to be a good street pad
The HPX pads in the rear still have a bit of life left, I will try the Forsa FP1 in the rear when the HPX and done
  • Like 1
Had a major service done on my lateral compartments
+20kw plus improved throttle and brake control
As you can see I am bedding them in now
Also went with some tint, all the cool kids are going orange
  • Like 1
Fitted the Forza FP2 pads in the rear to match the fronts I put in last week
Also purchased a little mechanic seat thingie with wheels for working on the brakes and suspension, makes life so much easier
  • Like 1
what happened ulleh?
Years of running and carrying a pack ended up screwing up my lower leg muscles, in the end when I was walking long distance the compartment stuff (sausage skin) that covers the muscles didn't stretch enough and the pressure started to cut off blood flow to my feet.
Should be all good now.
In other, more boost orientated news: the car is booked in on Monday for the charger, again, it cannot come quick enough, I've had to change the dates for getting the charger installed twice already, once for work and once for the surgery.
This time next week should be fun.
  • Like 1
So, the dyno results hey
With the blower at around 5-7 psi at it, it got to 317kwatw and about 950nm...
So a gain of about 47kwatw, but a extra 500nm of gearbox destroying, rubber laying torque
From talking to the tuner though the final kw number and shape of the curves can be taken with a grain of salt because of the highstall slipping, and stuff....... yadda yadda yadda......meh........it's all black magic to me
On the road, it's a freight train, I could only give it a little hit, but the before and after difference is, well, big
My next thing to do is revisit Craig's Automatics to adjust the autos tune, so it locks up a bit sooner, "or something" then hit the strip to see what it really does in anger
Overall, on day 1, I'm happy and haven't broken anything, yet, well, apart from traction
  • Like 8
I needed to pop back in to get the speedo calibrated, it was set to whatever the stock centre was.
I called and talked to Spiro and he said pop in whenever I was available, I said I am, he said bring it on in, so I did, he also stuck it straight back on the dyno and tickled the tune a bit because he wasn't happy with the idle when off throttle.
Excellent service
Everything is GTG now, plus I just took the long way back to work
It is nice and whiney, on the throttle, but not overly, you can only just here it in the cabin, which is nice, outside, it sounds :)
The car cruises like a dream
Coolant temps, on the stock gauge at least, hasn't changed, even when I was sitting in traffic for 10 minutes trying to get off Parramatta road
As for bonnet clearance, it easily fitted and there was no need to chop up my new under bonnet liner thingie, winning....
I might paint the trans cooler black to hide it a bit
  • Like 5
After a quick squirt with brake clean and some flat black rattle can action, I present......stealth mode
It's still wet but you get the gist
With no actual hands on prep, the fisheyes on the hoee clamps, and a few missed spots behind a bracket or hose, it is just like a Holden quality paint job...poor quality
IMO it does look better than before though
  • Like 4
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
