7 hours ago, R324u said:
I was able to make some progress on it  last night by doing this just saw your post., I had to set the dash to default, what car are you using this on an r32?  I’m using pin 21/ 30 for the ground but those wire colors  you mentioned don’t match up to what I have so I’m guessing you have a diff chassis
Yes those wire colors are specific to the R33
  • Like 1
Hey guys im trying to get my fuel level to work also on my haltech ic7 dash. I have an r34 4 door and im using pin 6 as signal and pin 55 as ground but im not getting any voltage value with a multimeter. I currently have 1/4 tank  and testing them two wires at the tank plug or at the dash i get the same reading (shows 0.01v this doesnt seem right). Can any one shed any light on this. Ive setup the dash on avi 1 and calibrated to 0 to 90 ohms, factory is ment to be 6 full 80 empty attached is a pinout for an r34 4 door for any one else chasing a diagram pin out. Am i missing a step or not testing the right wires??? Thanks guys
UPDATE
So i should have mentioned im fully replacing my dash with a haltech ic7 display so my factory dash was not plugged in
Once i plug the original dash in im getting voltage output there.
Fuel light came on and i was getting a fluctuating voltage of 1.0v to 0.9 volts fuel light just came one.
Filled up voltage now reads fluctuating 0.15 to 0.10 volt liters filled to this point was 51 liters so im lead to belive these sedans have a 60L tank so i know zero on my haltech ill have approx 10L left.
My question is if i unplug the dash will i still get a reading now or am i missing a wire to join in the harness iim lead to belive no
Edited by 26GTT
Far as the fuel reading it looks like you should be using pin 7 and 55
49 minutes ago, 26GTT said:
Thanks for the reply  mate, sorry thats a typo i am using pin 7.  So last night i tinkered with it a little more, with the factory r34 dash plugged in you get a voltage value but once you unplug the dash you loose these voltage values.
Are the wire colors from the fuel tank match the wires colors of pin 7/55?
ANOTHER UPDATE
So i now have it working and reading off the haltech dash 😄😄😄😄😄
But i still have a slight problem, im actually replacing my factory dash with the haltech unit. The 2 sender wires only have voltage when the factory dash is plugged in.
Both factory dash and haltech work and read correct but as soon as the factory dash is unplugged you loose the fuel level on the haltech??? Any ideas guys.
4 hours ago, 26GTT said:
the signal wire is yes (purple pin 7) but the ground wire is (black pin 55) at the tank and black white at the cluster
Only solution i have is find where the black wire ends in the cluster area and splice off it /  splice and run a wire from the tank to the cluster  / buy the fuel sender conditioner
  • 3 weeks later...
On a seperate note. Has anyone got flex fuel percentage to show correctly on the dash?
In the haltech I can see "flex fuel" and it shows the right ethanol percentage when I check it with a laptop. So my flex tune seems to be working (currently 48%).
However on the dash I choose "fuel composition" and it just displays 85%, never changes, seems super random.....
On 13/11/2020 at 12:35 PM, SLVRBAKSLPZ said:
I wired mine up about an hr ago and it worked..
The the red/gray wire for signal (i used pin 18
The teal wire is the ground for pin 30
Make sure to select the correct channel for the AVI you used. And use 90-0 ohm
The you select the spot on your dash for the fuel level choose the AVI, not fuel level.
You still are required to adjust the voltage.
So just confirming grey/red c29 wire to avi pin of my choice for signal and the light green/ silver wire c32 to earth input 30. Is this all you need to wire in for the fuel gauge to register?
Yes that correct. Sorry for the late reply
What voltage are you guy getting on your fuel sender? When i checked mine the Ohms read proper. When i plugged up to check the voltage i was getting very super low numbers (Full 0.02 // half 0.13 // Empty 0.42.
1 hour ago, 26GTT said:
So for my r34 sedan
Full is 0.2v
3/4 0.6v
1/2 1.0v
Fuel light 1.6v
This is using a haltech fuel conditioner in line to my ic7 as i found it helped the gauge be less erratic
That seems to align to what I have :)
9 hours ago, 26GTT said:
So for my r34 sedan
Full is 0.2v
3/4 0.6v
1/2 1.0v
Fuel light 1.6v
did you use the pull up at all? and whats your filter level?
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
