Trying to find a straight forward answer and see if anyone has had any experience with a 20det ecu in a plus T.
So I have a 20de ecu running in my plus T, stock injectors have been cleaned and a walbro 255 installed with adjustable fpr. It runs fine, boost fine, only on 5psi to be safe but looking to bump it up to about 7-10psi and was wondering if the red 20det injectors will work with the install of a 20det R32 ecu, I have found someone saying the timing is different and therefore will pre ignite etc. Surely someone has experience with this, my other option is a $130 speedlab chip for a plus T to run with red injectors.
https://www.sau.com.au/forums/topic/480187-rb20det/
8 minutes ago, Ben C34 said:
Oh sorry, I will try again. Yeah will work sweet. That's why every does it and reccomends it all the time.
Is that a better answer? May be the one you are looking for?
Bingo - you get the prize - that's the answer he was looking for !
But Nistune makes better sense ...
https://www.sau.com.au/forums/topic/480187-rb20det/#findComment-7928920
1 hour ago, Rusty Nuts said:
Have a read of these threads and make up your mind yourself, it will prevent more shit being thrown at you
Not sure what your point is Rusty. I didn't read all the way through but the main point is most people (except a fellow Kiwi I know!) used some kind of tuning device - power fc or emanage etc.  No one is saying that you can't add a turbo to a DE motor (although its not the best option) but rather that its difficult to account for different compression ratios, injectors etc without any means of tuning as the OP proposes.
https://www.sau.com.au/forums/topic/480187-rb20det/#findComment-7928925
1 hour ago, daninchainz said:
Nope asking if anyone has done it? no one deals with nistune in my area otherwise that’d be fine
Nistune tuners were hard to find when I started modifying my RB centuries ago so I had a guy modify an R32 ecu to suit but by now most tuners have come on board even though they would rather sell you a Link or a Motec. What is you nearest city?
https://www.sau.com.au/forums/topic/480187-rb20det/#findComment-7928926
Just now, daninchainz said:
Wellington region
OK my contacts are in Auckland, Tauranga and Christchurch but try a PM to Lithium  on this site and ask him if he knows anyone who will tune Nistunes in Wellington. You can buy the actual board direct from Nistune but they sometimes come up on TradeMe.
https://www.sau.com.au/forums/topic/480187-rb20det/#findComment-7928929
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
