hey everyone. As stated in the title, is there a center ring that is suppose to be in there around the hub so it is flush with my rim? Someone at the shop says yes I need one. If not a ring, then is it fine the way it is? I'll order one if needed but what is it called?
https://www.sau.com.au/forums/topic/480263-r33-gtst-hub-centric-ring-needed/
Rb hubs are 66.1mm
Most aftermarket wheels are 73mm and you will need hubcentric rings. What wheels are you using? If they are off another Nissan such as a 350Z etc they will most likely also be 66.1mm
9 hours ago, KiwiRS4T said:
Rb hubs are 66.1mm
This is a picture of the rim.
Its just a plastic or aluminium ring that takes up the gap between the hub and the wheel centres to locate the wheel when you put it on. The wheel studs do all the work holding the wheel in place.
Yes, this could cause a vibration. In theory if your wheel nuts are tapered as most are the wheel will end up centered on the hub even without the right size wheel bore or hub rings, but if it is even slightly off the wheel will be offset to the centre of the hub and will not turn evenly leading to vibration that increases with speed.
10 hours ago, GTSBoy said:
If the bore of the wheel is larger than the spigot on the hub, then yes, you need a ring. It's not completely easy to see what's going on there, but it looks like there's no gap.
When driving at higher speeds a feel a vibration through my steering wheel that I'm trying to eliminate. So far I've replace tires and control arms on all 4 sides. Now I have to replace the rear wheel bearing. I'm hoping that eliminates it. Afterwards I'll take her on highway to see if it dissappears. They just mentioned it at a garage about the ring and I wondered if that had to do with the driving. If you guys say there is no gap then I won't bother touching it.
It is unlikely that the absence of a hub ring is causing the vibration.  More likely it will be either a tyre out of balance or related to the wheel bearing (Although thats less likely).
Diameter should be 66.1 on the car and the same on the rim or if it isnt you will probably find that it is 73.1mm.  As has been said, take the wheel off and measure it.
To answer your original question the name of the ring that goes around the hub is hub ring. EG:
https://au.gktech.com/hub-centric-rings-pair
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
