I did my headlights a few years back:
https://www.gtr.co.uk/threads/r32-projector-hid-mod.172066/page-3
They are still going strong, but the chrome reflector has started to oxidise (yellowish) and now I just want to paint them back. I don't really want to be opening the headlights every few years to clean/rechrome etc.
The 78Works headlights caught my eye, modernise the looks of the car a lot, but would be great if someone posted a review on them.
6 hours ago, TXSquirrel said:
To retain factory adjustment, you will need to make a bracket similar to this or cut up your factory projector.
Nah, Lightwerkz have conversion brackets. It couldn't be any easier than what they make it. Except for all the baking the light open and the wiring changes, and so on.
The 78Works stuff is a Coplus headlight. You can probably get one locally and save on shipping charges. There's some threads on the "Morimoto" Corvette LED headlights which are also made by Coplus: https://www.corvetteforum.com/forums/c6-corvette-general-discussion/4152679-vette-lights-new-to-market-c6-corvette-morimoto-xb-led-headlights-group-buy.html
I contacted them a while back to see if they had an LHD variant but it sounds like they only make the RHD variant. I'm guessing that to get an LHD version of the R32 LED lights people would have to organize a non-trivial group buy.
Edited by joshuaho96
Ahh I see it, should make this job very convenient.  Is this new?  I was searching for a pre-made bracket like this a year ago but didn't find any.
4 hours ago, joshuaho96 said:
"The 78Works stuff is a Coplus headlight."
Thanks for mentioning that, i might buy a set come tax time. so i'll put up a review when i order them!
Looks like it uses a half decent LED projector, hopefully it's a Koito copy and not the crap ones.
Would be a good upgrade from the factory 1989 halogen projectors regardless.
Personally I wouldn't bother with LED projector unless it's Koito or equivalent, D2S is cheaper and you get great results.
  • 3 months later...
So i've finally pulled the pin and ordered a set from CT Auto parts, will put up a detailed review once they arrive
https://www.ctautoparts.com.au/coplus-dual-led-projector-headlight-for-89-94-nissan-skyline-r32-gts-t-gt-r-rb25det-rb26dett.html
I saw these listed on eBay for $2k the other day and just about died of shock (at the size of the price). I tried to find them on Alibaba to see if they were available for half that....but failed.
$1300 is only a little bit more palatable. They will want to be bloody good! I too echo the demand for output shots.
yeah the same compnay have them listed on ebay for 2k, whereas if you go on their website they are $1300.
They have been out of stock for ages. i bought a set and now they are out of stock again.
Will definitely get beam pattern shots etc (as best i can with an iphone 11 pro)
They don't list on Alibaba, probably because they're actually a company based in Taiwan: https://www.coplus.com.tw/home
I am keen on the results too @DaymoR32
I have been too tight to buy a set but have also been considering a HID conversion. Don't know what the popo would be more upset about: HIDs or something they thought were HIDs.
1300 dollarydoos is a lot but N1s are pretty awful
yeah $1300 is a lot but i did offset the cost by clearing some garage space of old parts from my previous 32, i've been hovering over the buy button for a while (as i'm a tight yorkshireman).
I also have N1 headlights which are horrific at night, so even if these new lights are terrible im sure they'll still be a bit better ?
Morimoto HID retro into original projector housings makes a lot of sense.
Back in the day, when almost no cars had HIDs, anyone who foolishly put HIDs into original housings (and even original projectors, as would be obvious given that there were no replacement projector options anyway) stood out like dogs' balls. Nowadays, nearly every new car >$25k has HIDs and many many are poorly adjusted and flash all sorts of shit light at people and anyone with a retro is not going to stand out. And, with an R32 with projectors, you can point to the fact that you still have projectors and say to the cop, "well, these things did have halogen projectors from the factory you know, so just because you can see projector lenses here doesn't mean I've jammed HIDs into it....." and hope that they buy it, should you ever actually get hauled over.
When I can get my shit together, this is what I will be doing.
In the meantime, all I have is the best white halogen bulbs you can buy, relays connected directly behind the globes and a fat power feed direct from main power to those relays to maximise the volts and watts. It's fine. It could be better, but it's fine. The high beams have more than sufficient reach and low beams simply don't really matter.
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
    • Short inlet runners cost quite a bit. Dulls off the off-boost torque, and delays boost onset, because arrival of boost is driven by gas flow is a product of the ability to flow air which is torque. This is the reason that the stock manifolds have longer runners. On a 3L, or bigger, you can usually accept the compromise of giving away some torque because the extra capacity gives you a little extra to waste. But on a smaller motor, there's not a lot there to start with. Example, I swapped RB20 out of my R32, 25NeoDET in its place. The "wall of torque" that I experienced afterwards made it all worthwhile. That's because I came from RB20 land where torque is not a thing. But I would not do anything, anything at all, to reduce the low/mid torque I have now, because I remember what it is like to not have it!
