Josh Williams possibly goes by Josh Redman or Josh Wills
Anyone know this bloke? Sold him a turbo, received a screen shot of a legitimate looking bank transfer so I sent it out with a few other things leaving that day before it cleared.
Money never cleared, and I got the usual story he will resend it, then the usual sob story he just lost his job and his mrs and he needs that $275 to live, then vanished. Has answered his phone once by mistake.
Lives in the Hounville area.
PayPal id linked to his phone number is Joshua Redman, but went by the name Josh Wills.
Only asking SAU as is email address is [email protected]
It's not much, but he's lied to me three times and wont answer my phone calls which is the piss off. I'll happily sell the debt to a local debt collector, or report to VEDA through my work as a bad debt.
Cheers,
Steve
hey mate,
I've experienced the same issue before (im in perth WA). The guy sent me a bank money transfer screenshot (comm bank) and I called up the bank and they told me the sender can cancel the transaction within 2 hours.
however, I've ended up randomly seeing his car driving past me not long after and I followed him to his house and next thing you know.. I got my part back (would not recommend).
just be careful next time and wait for the money to be cleared.
  • 4 months later...
Ok, his real name is Joshua Redman, mobile number is 0412 997 269.
He made one payment and then decided to block my number, I often catch up him slip up and answer private numbers to act like a stunned piece of shit and then hang up.
He claimed to have Covid-19 and had to spent his tax return on medicine so couldn't pay. Being Tasmania hasn't had any active cases of public transmission in forever this is very unlikely.
  • Like 1
  • 3 months later...
On 13/10/2020 at 7:50 PM, masTers said:
Andergrove is in Queensland not Tassie and there is no Shane Court in or around the Huon & Channel area.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
