G'day everyone
So for a while now my car has shown the same coolant temp which to me has always been low, so I finally decided to put in a new coolant temp sensor and WHOA it's now reading full hot, but the weird thing is my car, despite reading that high doesn't 'feel' hot.
  • No 'boiling' water
  • no loss of coolant
  • no milky stuff in oil
  • radiator can be touched without burning me
  • no smoke/fumes/burning smell
What on earth could be causing this? I might purchase a new radiator and thermostat but before I do, anyone got any advice on troubleshooting the issue?
Car is completely stock besides exhaust. Last weekend I changed plugs and did valve cover gaskets as well.
The before and after images of the temp with the new and old coolant temp sensor.
From one extreme to the other, does it jump straight to that hot position or gradually work it's way up there as the car warms up from cold?
Most would recommend installing an aftermarket gauge that shows actual temps before trusting the factory gauge. Would be cheaper than chasing a heating issue that may not be present.
Well it rises to half very quickly and then after say 10 minutes of driving will hit the top, stagnates at half for a little while. I’m hoping it’s not because I used an after marker temp sensor (tridon brand)
I think you will find that is the case. The position the original sensor was showing looked about right.
I might try giving the OEM sensor a really good clean and see if that changes anything, hopefully it can be revived
3 minutes ago, GTSBoy said:
FFS! How about applying a little bit of science?
What do you mean? I’m not that clued on with your original post man, how does one measure resistance
Did you mean to Google that? Or ask random People in a forum? Because I would suggest googling it
I came here to get some help, not be told to google my issue, i’ve tried that. Any other good people in the forums have some advice that are willing to help a fellow enthusiast
2 minutes ago, robbo_rb180 said:
I don’t have a multimeter, maybe I should have made that clearer earlier.....but thanks
You've been told what you need to do to check the sensor is right. When you're relying on people to diagnose/repair it there is never a correct answer/solution with out doing some of the work.
https://www.supercheapauto.com.au/p/sca-sca-multimeter---digital/387595.html
One of the best tools to own when trying to diagnose electrical issues. A quick google search and almost every basic problem is fixable with out asking questions on a forum.
I miss the times before the internet was everywhere.
  • Like 1
Understood, that’s why I came here but i need to look at getting the correct tools so I can diagnose.
You gotta understand that not everyone has the same knowledge as you, so be patient....thanks for the help ?
Your words. Google that.
a multimeter is like, 15 bucks? or less off ebay. Less than the sensor anyway. Have you checked the coolant? maybe the refill was fkd up and the car is actually running too hot.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
