Previous owner in japan seems to have disabled my cel and I can't figure out how to fix the issue. I get nothing when I turn the ignition on and when I start the car. Checked the bulb in the cluster, it's fine. Checked continuity from the bulb trace to the ecu and that's fine. #32 orange black wire. The ecu seems to not be sending a signal to the bulb. Tried activating the codes via the consult plug and that doesn't get it to light up either. On a side note, i can't get my laptop to connect to the ecu either. Using datascan. I am literally at a loss.
Edited by "G"
https://www.sau.com.au/forums/topic/480830-no-cel-r32-gtr/
Turns out the ecu fuse (10 amp) was blown. Now I have a cel while cranking. See attached video. Is this normal for it not to turn on while ign is on? Also i still can't get in to the diagnosis mode to read codes. I am arcing the 2 pins for 2 secs. If i have no codes is anything supposed to happen?
I still can't get my laptop to connect to this program >> https://conzult.com/
Is there a better software i should be using?
celv.MOV
Edited by "G"
https://www.sau.com.au/forums/topic/480830-no-cel-r32-gtr/#findComment-7936978
