Shed clean out of various R32 GTST Coupe parts when stripping my race car
To many to list individually
Message me if interested
Pick up from Dapto NSW
Happy to ship at buyers expense
Can provide higher res pics of individual items if required
Cheers
Jason
Hi,
I would like to register my interest in;
  • The front window mirror inside panels (the plastic triangles).
  • The front indicators (provided they look pretty schmick - I don't need them if they've got chips/cracks etc.)
  • The air-con controller (provided it's working)
  • The seat belts (provided they're not frayed on the edges and are otherwise working)
  • The door window mechanism (provided it's working)
  • The wastegate actuator (provided it's the stock RB20 10 psi unit and you're happy to keep it separated from the turbo!)
If you come up with a $$ number that you'd like for that lot and an allowance to ship to SA, send me a PM and we can discuss.
cheers
Do you happen to have the seat belt retainers with the release button that the buckle lock into for the front seats?
54 minutes ago, GTSBoy said:
Hi,
cheers
No problems
Ill take some better pics of these items and send to you.
The front window mirror inside panels (the plastic triangles). No problems
The front indicators (provided they look pretty schmick - I don't need them if they've got chips/cracks etc.) Some scratches, and one of the mounting tabs broken on each indicator
The air-con controller (provided it's working) Not 100% sure, was disconnected when I bought the car.
The seat belts (provided they're not frayed on the edges and are otherwise working) No Frays and are working. Still have the passenger front in the car so its only the drivers front and both rear
The door window mechanism (provided it's working)Yes, working Bought to fix my drivers door, but just using passenger side switch to do both windows
The wastegate actuator (provided it's the stock RB20 10 psi unit and you're happy to keep it separated from the turbo!) Actuator is off RB25 turbo. I am now using the RB25 turbo with RB20 actuator
I think so, but didnt find them when doing the clean out. Ill have another look and let you know
  • Thanks 1
3 minutes ago, Jasoncauser said:
No problems
OK. Some changes to my list based on your feedback.
Indicators and wastegate actuator can drop off the list.
Air-con controller is a mystery proposition, so value is low. Still willing to risk it for a low enough price.
Driver's seatbelt is the main one I'd be interested in anyway, so the missing passenger's is OK.
Better pics of mirror panels, air-con controller, belts & window mech happily accepted.
No Problems, Will take some pics tonight.
1 minute ago, DaymoR32 said:
price on the front indicators?
They do have a few scratched and each one has a broken mounting tab.
give me a figure your happy with
Can send better pics if still interested
grab a few more pics and we'll go from there mate :)
That would be awesome if you could. Thanks.
  • 1 month later...
  • 10 months later...
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
