I need help with what I should do with my diff it’s a Active LSD with a altessa pump system. It singles and I want to to double what can I do with this diff bleed it, weld it, get it shimmed, block off the altessa system? Idk what to do please help as I want to use my car for drifting / road use
https://www.sau.com.au/forums/topic/481063-r33-gtst-mspec-active-lsd-need-help/
So you didn't go and read about the active LSD as I suggested in the other thread ? In the drivetrain section there is a whole thread stickied at the top on the thing.
I could not find it sorry new to this site I’ll have another look
Basically you options are to bleed it and get it working back to factory 100%, or replace the entire housing, centre and driveshaft axles to go to any type of mechanical LSD. As mentioned earlier, ALL 33 and 34 GTR v spec have this type of diff too.
Basically you options are to bleed it and get it working back to factory 100%, or replace the entire housing, centre and driveshaft axles to go to any type of mechanical LSD. As mentioned ALL 33 and 34 GTR v spec have this type of diff.
Could I weld it ?
It actually astounds me that no one has ever produced a readily available LSD centre to go into the viscous LSD housing (unless I've missed something???).  A mechanical LSD diff housing is worth the GDP of a small African nation nowadays whereas a viscous LSD diff is worth a packet of Tim Tams and maybe a sneaky wristy no spit.  The person who makes it happen economically is going to make a lot of money and all of a sudden a near worthless hunk of boat anchor is worth money again!
If it's welded you could do nothing else as it's no going to "actuate' anything.
I know right ? I'd be the first one to get one for the v spec !
No. Not right.
There is little difference between VLSD and mech LSD (and in fact, the open diffs in NA cars etc) when it comes to the housing. There are literally dozens of mech LSD options for VLSD diffs. All of the usual suspects (Cusco, KAAZ, Nismo, etc etc, and many more) have mech diff replacements for VLSD and open R200 centres.
The only mech diff centres on any R chassis cars were the GTR 2-way mechanicals. And I suppose the helical diffs on some R34s can be consider mechanical too, just not in the same way. That's why they are rare and expensive.
What there is not, is something to easily put a mech centre into one of the ACTIVE diffs from the M-specs and V-spec GTRs. Because they make it difficult, and there was only a small number of them, and there are other diffs you can grab to put in their place.
  • Like 1
Wut? ..you're not including mechanicals i'm assuming.
39 minutes ago, tainer33 said:
If I welded it would I just put a bolt into the whole that the altessa bolts into?
I doubt that you could weld it. It's got hydraulic actuated clutches inside it and other shenanigans. Plugging up the hole where you pulled a hydraulic line out of it is the least of your worries!
And it is not altessa either. It's ATTESA. And what you have is not ATTESA. It is just active diff bullshit. ATTESA is 4WD. Which you don't have.
Huh??
1 hour ago, Shoota_77 said:
Sorry gents, I have to clarify.  I've been talking about diffs for the GT-R.  I don't know of an aftermarket mechanical centre for those.
Yeah, but still. GTRs only have 2 sorts of diffs.
The normal one is mechanical 2-way. No reason to talk about that any more.
The other is NOT a VLSD. It is the active diff. The V-spec diff. You are right, there are no mech centres to replace those, but there's also not very many of them out there, so why would anyone bother putting the effort into developing product?
I haven't looked on GTR registry for exact numbers, but that is far from correct. Off the top of my head about half of the 33 GTR is v spec with active LSD and in 34 GTR most of them have the active LSD. It is heaps rarer to have a 34 GTR with a non active mechanical LSD.
Yep, every one of these 34 GTR v spec, v spec ii,  N1, m spec and Nur spec have them. Even the halo Z tune has it, "specially tuned" as Nismo puts it.
Good in theory.
32 v specs 1 + 2 have the goods with the 31 spline mechanical LSD.
Yeah can't believe there is no a-lsd mechanical centre replacements after 25 years, they would sell like hot cakes
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
