I got a pretty good question for y'all that i cant find an answer to no where.....
In the event that my r34's 25De+T small box may one day give up with the abuse of being boosted and drifted, What would be involved with changing the small box to the R33 big box?
My Main concern would be driveshaft compatibility, i do not think that my current stock drive shaft will work. Can anyone please shed some light on this, anyone ever done this in here? Any ideas or advice is welcomed.
Thank you.
https://www.sau.com.au/forums/topic/481156-r33-big-box-on-r34-gt/
18 minutes ago, Unzipped Composites said:
I'm not certain because I used everything from a 34 donor car, but considering the gearbox is the same I imagine the 34 GTT tailshaft will fit if you are also using a GTT diff?
No. He's starting with an NA gearbox. It's a DE + T
Yeh, I started with the same. But didn't go +T, I just swapped everything in from a donor GTT. Engine, gearbox, driveshaft, diff.
But where is the difference? If he changes to an RB25DET gearbox, then the tailshaft should fit? The 33 boxes are the same as the 34 boxes other than pull/push, are they not? So provided the diff is changed too, then it should all just bolt up?
34 minutes ago, robbo_rb180 said:
You need the big box tailshaft from a r34 gtt as splines are different.
Sorry but can you explain a lil more? my car is the 1998 ER34 25GT COUPE non hicas... so what you are saying is that i would need the front half of the r33 gtst's drive shaft as the spline that goes into the gearbox is different? Would this also mean that i may need to shorten or modify the overall length? Thanks for the reply by the way
3 hours ago, Dil-Dog said:
need the front half of the r34 GTT's drive shaft as the spline that goes into the gearbox is different?
Fixed that for you.
Yes, the gearboxes are different (NA cf. turbo). The length of the box and the output spline, obviously.
Yes, the front half of the tailshaft of an R33 or R34 turbo will go into the box. But I changed your quote to say R34, just in case there is a length difference between R33 and R34 tailshafts. You need both the spline and the tailshaft length to match.
It's also why I said cut and shut in my first reply. It may not be strictly necessary in this case because of the possible and likely existence of a tailshaft piece that already suits (from an R34, possibly R33). But when you do this into an R32 you have to cut and shut tailshafts together.
  • Thanks 1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
