Post up the boost control table.
I couldn't watch the video but it sounds like you're asking the boost controller to cycle around the idle areas of the map. Simply pull the duty cycle out of those areas of the map, it's not like your making boost at idle anyway lol.
Edited by Murray_Calavera
  • Like 2
I haven't messed with the boost table at all. I loaded the base tune and adjusted MAFs / TPS output for the ATESSA / fuel sender
Here's what the boost table is set to.
38 minutes ago, RTSKY33 said:
I changed the options on the link so everyone should be able to view it now.
So that's going to be commanding 22 %, change the first number to 0 and all good, then adjust the axis values to more sensible values
I set the first value to 0 and it fixed the issue. Im new the ECU things so I'm not sure of what the other value should be set to.
Thanks for helping me out!
The stock solenoid works differently. It is pulsed from standard, but thats not practically the problem. The problem is that when de-energised it is normally closed, as opposed to normally open as you would with a 3 port Mac valve setup with wastegate actuator. The vacuum arrangement is different when using a normally open valve too.
The stock solenoid feed from plenum is tee'd and directly the feeds solenoid and wastegate actuators, then ecu commands solenoid to energise and open, bleeding off the excess boost pressure actuator boost signal to back Infront of the turbos. A normally open Mac valve would not be tee'd and be fed directly from plenum, then to actuators. This normally closed setup is more like an external gate setup, except the bleed port is going back in front of turbos as an actuator air bleed instead of going to the second preloading port on an external gate.
Why Nissan why ?
Stock setup is stupid and appears to have problems controlling higher than stock boost pressures, that is, not being able to bleed off enough air to raise / control boost properly, reliably or consistently.
2 hours ago, BK said:
Why Nissan why ?
Because it's just a 2 state bleed. It's a digital on-off arrangement. With Nissan it's X (where X is a fixed 5 or 10 or similar) psi from the spring with the solenoid closed and Z (=X + Y where Y is a fixed 2 or 3 or 5 or something similar) psi when open and bleeding.
Mac valves are throttled by the PWM controller to give an analogue effect. With PWM control, it's X + A where A can be anything at any time depending on the limits of the bleed size, duty cycle limits, etc.
  • Like 1
So replace the stock one with an automotive MAC Valve. As its Provisioned for PWM it will work intended with the Haltech ECU, correct?
also, will using the same plumbing/wiring be an issue?
Edited by SLVRBAKSLPZ
1 hour ago, Dose Pipe Sutututu said:
Wiring fine, you'll need to slightly replumb
Is this accurate on how to modify the plumbing? Port 1 vent to Atmosphere // Wastegate to port 2 // Direct from plenum to port 3
Looks about right, diagram is giving me a headache lol.
Essentially you want the boost source from your plenum (only applies to RB26 as throttles are post plenum).
Essentially you want the boost source from your plenum (only applies to RB26 as throttles are post plenum) and block off the OEM bleed.
Im sorry. seems all the pictures on Google are already scribbled on.
But basically the long green line needs to get routed to the plenum where the short ones goes into, correct? It looks like I can reach that line and re-route w/o pulling the plenum.
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
