Hi guys - This is doing my head in and I need some help.  12 months ago I rebuilt my LHS headlight assembly as the glass was broken - all three lamps worked as expected small side orange/projector/main headlight, all good..... fast forward 11 months and that LHS headlight assembly only now has the small side orange light working.  I spent considerable time testing with a multi meter - checking the lamps, was I getting voltage at the sockets.... there was no voltage and lamps tested fine.  I reseated all relays, checked & tested fuses, fiddled with switches (if only a wiggle) and sharp taps! and still nothing!
Got fed up and forgot about it until just now - 2 months later as I had not driven the car since - The car started perfectly - when I turned the headlights on BOTH projector lamps came on - I was surprised, so I turned high beam on and.... the projector turned off but the main headlight never turned on. So I went back to low beam and sadly the projector now refuses to turn on. I've tried every switch configuration and both the LHS projector & headlight will not turn on, only the side orange lights. See table below:
What should be the lighting changes with the switch configurations - As I can tell the dash switch does nothing - what should it do?
Can anyone give me some advice on what the issue with my LHS headlight assembly may be?
How can I test the relays?
What else can I test?
  • Like 1
https://www.sau.com.au/forums/topic/481404-temperamental-headlight-on-r32-gtst/
By "dash switch", I'm guessing you're referring to the push-button, next to the round switch.
It is for fog lights - in the absence of fog lights, it simply turns on park lights - has no effect on projector / main.
Your left lights are working as designed, the problem with the right is, as GTSBoy suggested, a problem with the contacts in the rotary switch.
  • 1 month later...
33 minutes ago, niZmO_Man said:
I say this in every thread like this: put on H4 relay harness. Don't rely on the standard switch to push through adequate amps for your headlights.
While I don't disagree (I actually agree completely, except perhaps for most R32s not having H4 globes!) - just adding the relays doesn't actually solve all problems. The original headlight switches are intended to have a certain amount of current flowing through them. This current does what is called "wetting" the contacts. That wetting action is a big enough arc as the contacts make and break to burn off some carbon, basically keeping the contacts clean enough to keep working.
When you remove all that load and get the contacts to just switch a relay, the current being switched is no longer enough to wet the contacts and they can start to build carbon. It can actually be worse/more annoying than the high current too hot scenario that we try to solve with the relays.
The answer is to understand what is happening and deal with it appropriately.
The projectors have that little splitter thing and it connects to H4 plug (hence my H4 harness suggestion).
I agree with you on fixing the bloody switch contacts, but once I cleaned/bent the pins and bunged in my harness, never had an issue.
My GT-R came with burnt plug (at the switch). I'm guessing previous owners tried running 100W H3/H3C bulbs.
  • Like 1
Well I think my switch has had it - it remains temperamental sometimes it works some times it does'nt .. Cleaned the contacts with wet n dry, used contact cleaner, applied dielectric grease and bent the pins a little .. I think I'll have to bite the bullet and by one for close to $200.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
