For some reason my '05 350z will get stuck in first gear when parked on a hill, this is only if the gearbox is holding it (if the handbrake is, its fine).
I won't be able to pull it out of first gear, even if I push the clutch in with the car off and it won't roll back either even with the clutch in.
The only way to release it, is to turn the car on with the clutch in and then I can pull it out but it always makes a big thud.
Is that normal, in my R33 I can push the clutch in even with the car off and load on the transmission and change it out of 1st.
I don't see that as a reasonable excuse for not engaging the handbrake, at all.
I hope you're at least turning your wheels in the right direction for your vehicle to veer into the kerb so that it doesn't roll off and damage someone else's vehicle or kill someone.
Pardon my judgmental attitude but part of motoring is thinking responsibly about everyone around you and your heavy steel weapon. We have parking brakes for a reason. They are the primary safety device, not your gearbox.
Let me say I almost never use the park brake on my autos, but that is a very different situation to manual.
Auto has a pawl which locks the gearbox. Manual is just using engine compression to hold the car which is not safe depending on the slope or unexpected extra load like another car or a person leaning on it ;)
I think best practice is pull up to a stop with foot on the brake, pull up the hand brake, release foot off the brake pedal, turn off the car, clutch in (or not, don't think it matters once car is off) put the gearbox in 1st or reverse depending on whether you're facing up/down.
I do this in autos too, foot brake, hand brake, release foot brake, put lever into P.
I'm not so trusting of that idea either. I know of two people with two vehicles whose pawl did not hold their vehicle at all and made quite the amusing ticking sound as they rolled away from them. One caught his vehicle in time. The other, well, the write-off was a blessing in disguise anyway. To me, they're always a backup to the parking brake, not a primary.
Many cars do have neutral inhibit on manuals.  The Holden Cruze has such a crap handbrake they will roll away unless you crank it on hard and the owners manual specifies to leave in gear. Mate had one roll out his driveway across the road into neighbor's yard. Everyone was ok luckily , and from my perspective it was very funny.
It always is when it's not your car. :P
Which reminds me, I need to readjust the parking brake on my V36. Nobody has really been capable of giving it a proper adjustment, working on the cable instead of the shoes themselves. I always get a little nervous creep from it.
On 24/02/2021 at 1:33 PM, Ben C34 said:
Squeezing the oil out of your engine bearings to hold the car on a hill sounds like a shit idea to me.
Hey @Ben C34 was this directed at my method?  Just would like to know how you mean as I am a mechanical numpty.
Cheers,
Edited by JGTC
Cheers,
Not you directly mate. What you have described doesnt load up the gearbox and then engine unless the hand brake doesnt hold.
Cheers,
On 2/24/2021 at 3:06 PM, GTSBoy said:
I never leave a manual parked in gear. Accidental key turning can result in panel damage because there is no neutral inhibit on a manual.
The handbrake is there for a reason.
Everyone here veered straight off what I was trying to ask, I wasn't after a safety lecture. I don't usually leave the car in 1st gear on a hill ffs.
What I was trying to ask is, if I am on a hill and for whatever reason the gearbox is the reason its being held on the hill (lets say its in a controlled environment, in the middle of mexico, with bubble wrap all around it and cotton wool just in case) it won't let me pull it out of gear (even with the clutch pushed in of course) unless I start the car.
That is on my V35 with a twin plate, solid center clutch. It's been in the car for over 20,000km and doesn't show any other signs of dragging the clutch.
My R33, you can hold it on the hill in gear with the gearbox and if you push the clutch in even with the motor off it will let you pull it out of gear, the v35 doesn't do that.
Is that a symptom of a twin plate clutch, or is there potentially something else wrong - like maybe clutch drag even though I highly doubt that being the issue.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
