So i brought this car a year ago with 250k on it with a blown ECU and a tight cam belt, Fixed that and is was a new car again. The problem has been that the compression cold is 140psi throughout the 6 and once hot they all drop evenly 20psi down to 120psi throughout the 6. its been like that for a year now and hasn't changed. it doesn't use oil really and doesn't fill up the catch can. the k&n filter on the catch can looks abit oily however. There's no noticeable blow by just a puff of white smoke out the catch can when you give it a hard rev.
I haven't done a leakdown test yet I've been putting it off. my question is what causes compression to drop like that? i have no information on the history besides it was owned my crackheads and it sat dormant for possibly more then 5 years. the motor looks super clean for how many km's it has and how trashed the suspension is. the car runs perfect but i can feel the 20psi loss as the car warms up.
i was thinking someone put a thicker head gasket on to drop the cr but that still doesn't answer the compression drop. its suppose to rise isn't it lol.
I've asked many mechanics and they cant explain it.
Hope someone can help!
Thanks.
https://www.sau.com.au/forums/topic/482142-r33-gts25t-compression-issue/
3 hours ago, blind_elk said:
Have you done a wet compression test?
Its a good idea, but it will confirm worn rings. The suspension didn't get rooted because the crackies drove it to church on Sundays. Or down to Supercheap for new filters, before the car wash.
Edited by Rusty Nuts
additional information
  • Like 1
hmm, its running 10psi atm, iv blown 2 turbos so far going any higher on the stock ones. Im still confused why the compression dropped 20psi just from warming up, and even more so why its 120psi hot and cold a year later. wouldnt it drop down to say 100psi once warmed up if its worn that much in the time iv owned it. if compression should be around 160-170+ and i have 120, shouldnt there be quite abit of blowby?
I forgot to take the crank case vent valve out of the manifold to get a true reading of how much blowby there is, i dc that. i took the catch can hose out and you can bearly notice air coming out, you have to squeeze the hose end and then its enough to feel like a gentle flow of air. 0 smoke. same if you give it a rev.
iv used the same comp tester for years to eliminate getting different readings.
Edited by JasonMate
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
