I vote for Hypergear Turbos, have used 3 of them myself. Tao @hypergear is quite active on these forums.
I would suggest getting the ball bearing option, day & night difference from the journal bearing.
Be aware that a Hypergear turbo is not really a direct replacement from an engine management point of view. They make more boost and flow than the R33 ECU will be happy with. Talk to Tao about your options to keep the new turbo not so far away from the capabilities of the stock turbo so the ECU doesn't shit itself.
Then just get a @Toshi remapped R33 ECU (yes it is possible, only very select people can do it) for 1bar boost, FMIC, stock injectors, stock MAF, better fuel pump etc.
Should give you about 190~210kW at the rears.
  • Like 1
I have gotten contact with one who has a original Turbo, the rest of the engine is not original though. I have an Apexi ECU, biggee injectors and some stuff inside the engine.
Should have said so before. All our warnings and information about not going too big on the turbo can be ignored. A bigger turbo would be fine. Probably better to spend a bit more on something new rather than a stock ceramic time bomb.
Yeah but the thing is the car inspection does not like bigger turbo, i have an Garrett 34xx already but i want it to "look" original so it can pass inspection. So as soon as it has passed inspection i can swap back go the better turbo.
So i wont boost it more than 0.8 and map it to as close to original as possible then have a map with the better stuff.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
