Hey guys, I'm new round here.
I'm thinking about buying a car in about 3-6 months these are my options from the research I've done. (20-25K budget and I'm on red P's)
1. A non turbo Skyline. From what I've heard it's not a good idea to turbo it later on. But maybe I can reuse the parts if I get a GTT later on and just swap them in. My concern is also resale value, which r34's seem to be holding on.
2. WRX. Non performance. I don't know how good these will be performance wise but they seem the most liveable.
3. The safest and cheapest option I have is an 86 or BRZ. Probs won't turbo, but I can mod it I guess. Only issue is don't think it's a great car long term and resale is kinda trash from what I've seen.
I'm leaning towards the r34, but if anyone has suggestions, would be greatly appreciated!
https://www.sau.com.au/forums/topic/482524-skyline-r34-non-turbo/
I would say forget the Skyline, get the 86. 86/BRZ being the more modern car will be the nicest to drive, so that would probably be my pick. Plus less police attention, decent aftermarket options, etc.
  • Like 2
There's nothing a R34 does better than an 86.
Nothing.
A R34 N/A is not a performance car. It's closer to a Hyundai Tiburon if anything. A R34 Manual GTT in stock form (I.e out of the price range anyhow) is about the same performance in a straight line as an 86 anyway lol.
Also there's plenty reasons why P platers love hot hatches too, as an alternative.
  • Like 2
Yeah, I'll have to agree on the aftermarket on the 86. Thanks for the input!
I've looked at something like a Golf GTI or R as an option, with 4 seats and all. 86 does sound like a better idea though.
I would take a Golf R, faster better, much more comfortable & safer.
Flash, dump pipe, better intercooler, better intake and you'll toast most turbo charged 86 shit boxes.
  • Like 2
Sounds like a plan. The R does look quite nice and 4 doors...
Does the turbo go stututu though
Intake pipe, pod filter, pod enclosure and either delete the BOV (DV as they call it in their realm) OR just get one that's adjustable and clamp it down tight for that doseeeeeeeeee life.
  • Thanks 1
Golf R great choice as well, impress your mates and ya mum at the same time!
Seriously though, those little VW's are pretty quick. Between the 86 and the Golf, you've literally just described almost half the regular field in our local time attack series haha. None of them are anywhere close to winning, but they're giving it a red hot crack 😅
  • Like 1
  • Haha 1
I always think Lancer Ralliarts are the biggest unknown sleeper. Same drivetrain as the Evo X, with slightly slimmer bodykit. Same potential.
Look pretty shit though.
That said, also cheap. Unsure if P platers can drive them but if they can, then oh boy there's potential there too.
  • Like 2
Yeah Golf R is probably on the table if I get one for a good price. As long as they sound good I'm not too fussed about speed especially on the P's.
I was looking at one this morning! Price range is definitely a big pro but yeah, they look worse than my 2006 corolla hatch hehe
  • Like 1
However, they are legal (as are the sedans) and the Evo X platform is going to run rings around any hot hatch, especially if you go modding. The sedans just look like a lancer instead of a WTF is that hatch going on.
Yes yes, mods are also not really legal but there's plenty of uh, invisible mods that go on that evo motor.
The sedans don't look so bad....might get some cop attention but it seems like a good choice too...thanks for adding another option now I'm confused aha
Here's an idea, buy a R33 GTS-t OR R34 GT-t, de-rego it and just store it.
Buy a P plater fun, stock car, enjoy it. Then once you're ready, sell and play with the whooshy break oil pump Skyline.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
