Had a turbo swap done from twins to single with some other parts replace (below). Before I brought it to the shop to start the work, I had to compression tested and results were C1-115, C2-118, C3-119, C4-121, C5-119, C6-119. Half way through the work we found a problem and had to get more parts so the car sat for about 8-9 months without starting it. When they finally had everything sorted and put it on the dyno, it was only making around ~260hp at 15psi with an HKS GT3-4r. They compression tested it after and results were C1-70, C2-90, C3-100, C4-100, C5-100, C6-100. They think that the reason it isn't making power is because of the low compression, and they think the low compression could be due to it sitting for months or the engine just waring down. They think there's a chance that compression could come back after driving it for a couple weeks, if not they are suggesting a rebuild.
Any suggestion on what could have caused compression to drop so much suddenly? Anything in particular to check? Could it actually be from the car sitting for 8-9 months?
Mods done:
HKS GT3-4r
HKS Manifold
HKS Downpipe
HKS Fuel Rail
HKS Fuel Pump
HKS Coil packs
HKS BOV
ID 1050x injectors
Tomei Fuel Pressure Regulator
Greddy Boost Controller
Platinum Pro ECU
https://www.sau.com.au/forums/topic/482713-rb26-low-power-and-low-compression/
This is bullshit of the very finest sort. Take the car to a more intelligent workshop.
Compressions may decrease while a car is sitting if some grunge built up somewhere hardens and perhaps stops valves from seating properly. Or the rings might get sticky in the grooves. But that sort of thing isn't usually permanent. It should come good after a brief run.
It is far more likely that the compression tester is reading low. Even if it is the same compression tester. There are so many "mechanics" that simply have no f**king idea that the performance of their test gear can change and that they need to keep it calibrated if they are going to trust their measurements.
This aligns with what I just said, although I would hope and expect it to be much faster than a couple of weeks. One good drive should do it.
  • Like 1
On 8/7/2021 at 12:27 AM, Duncan said:
Well....the battery could be flatter after sitting there all that time.....
But, no, compression doesn't sneak out on it's own.
Haven't tested with a multimeter yet but stock gauge shows around 14V.
On 8/6/2021 at 11:15 PM, GTSBoy said:
I'd also like to point out that ~120 psi comp readings, like your first set, if accurate, are quite low and probably low enough to explain the low power on their own. My 25Neo measures ~175-180 psi (with only slightly higher stock compression than a 26)
After a couple drives it doesn't seem to have any more power. As far as compression goes, I didn't put the car on the dyno before the turbo swap but it feels like it has less power than before and I was on stock turbos before, so it would make sense that compression is lower since the boost is higher now.
Is there anything simpler / cheaper I should have checked before going the route of a rebuild? Maybe the head gasket or valves?
On 8/8/2021 at 7:36 AM, SnekDoc said:
Is it true that if I put a little oil in the cylinders, compression test it again, and if results are the same then it is likely head gasket or valves?
Generally, yes. But there are no "rules" here, as different things can happen to any engine.
But I simply cannot think of anything that would cause all 6 cylinders to drop compression by about the same amount while sitting doing nothing. The sort of sludge hardening stuff I mentioned earlier seldom occurs evenly across an engine.
I am going to put $10 on it being something else. Maybe something messed up by the workshop.
Do a Leak down test yourself.
Check for any leaks on the intake or exhaust manifold.
Have someone who knows what they are doing look at your tune-they may have removed a lot of timing. Pm me or @Dose Pipe Sutututu your tune file
Check that the cas is setup correctly with the ecu- see above
  • Like 1
I'll have to get a leakdown test kit and learn how to use it, I'm still pretty new to all this.
Looks like the tune is password protected so I'll try to get the password when they reopen in a couple days and send it over, I appreciate the help.
On 8/7/2021 at 9:16 PM, Dose Pipe Sutututu said:
The list of HKS parts hurt my eyes 😆
I knew I was going to get shit for that here
haha, hey it's your car and you can fit whatever parts to it :)
At least you didn't replace the twin turbo bullshit with another set of twin aids - so points there!
And yes, send over the tune to either of us and we'll have a look.
  • Like 1
  • Haha 1
On that, can you get around a password on a haltech?  Send it back to the factory for a reset maybe?
If said 'shop' won't give out the password, is a new ECU the only answer?  Surely somebody has found a workaround somewhere in the world?
Or are we still waiting?
Can't get around password lock on an Elite, but it only protects the current map. You can still load in a different base or saved map or reinitialise it and start again though. Pretty sure it's the same for a Platinum too.
On 8/11/2021 at 3:36 AM, robbo_rb180 said:
being an older platinum would be start from a base file and go from there.
@SnekDoc where are you located?
I'm in the U.S. I have another tuner I can go to that's a bit farther away that I know is good, the main reason I went to the one I did is they are much closer, I had heard good things about them wrt RBs, and the tuner that is farther away wanted to do additional things to the car that I didn't want to do / pay for at the time. My main concern right now is getting the compression back, and if that is something the shop caused that I should try to get them to cover or if I should cut my losses and go to the other tuner.
Compression doesn't just disappear. One cylinder getting low relative to others is a really, really bad sign. If it has decreased then the most likely explanation is bad ECU settings or something else have damaged the engine. Also the absolute number for compression is heavily affected by things like battery health/state of charge, whether you actually WOT properly while cranking, etc. You don't just "get compression back", you have to fix whatever is leaking compression.
  • 3 weeks later...
Had it compression tested again, readings were C1: 100, C2: 95, C3: 105, C4:110, C5: 100, C6: 110. Better than last time time and at least fairly even but still lower than originally. Air appears to be leaking into crankcase so consensus is going to need a rebuild. Time for a whole new rabbit hole and a lot more money.
Now need to find out how far I want to go upgrading things if I'm having it rebuilt. My goal was to eventually make it a track-ready 2.8 but wasn't planning on doing it this soon.
I know you guys aren't big on HKS parts, but since I'm not doing the work myself what do you think price-wise about going with a complete engine like the HKS step 2 or the Tomei one vs having a shop rebuild my engine with all the equivalent done?
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
