Hi I bought a Nissan Skyline R31 Silo.
Basically I had to swap my motor because it was buggered, ended up buying another rb30 motor which came out of a wrecked VL wagon from Sydney.
The thing is I am not sure if I can turbo it.. I am not to familiar with A8 blocks and what not.. would not know the difference so if anyone could help me find out if I can turbo it please let me know ill send some photos through, of what I think is the hole for the oil feed
Any tips in general especially when it comes to what type of turbo and what not to get would be greatly appreciated
You can run an oil feed from the cold side to feed the turbo. Normally -4 (4an) braided hose is the go. If you haven't got a spare 1/8" npt port on the oil filter housing you can buy adapters that give you extra ports.
Something like this-
If there is no oil drain in the side of the block you'll need to weld an AN fitting onto your sump to return from the turbo into. Something like this-
  • Thanks 1
Then whats the whole big deal about A8 or whatever its called ?
i can see now that it can be done maybe they just say that because theres more f**k around to it ?
as well i was told if its not an A8 that it wont be able to have as much boost is this true?
im gonna get some photos of my motor in a few minutees just waiting for my phone to turn on
What difference do you think the block makes?
There is clearly a plug in there you pull out for the oil return. So that's handy . Oil feed is super easy to sort out as per above post.
Are you going to turbo a 30yr old wrecker engine? Sounds fun.
  • Sad 1
yeah well i plan on thrashing it a bit first then getting it rebuilt then chucking in a turbo.. but i want to make sure i have the right motor for it
Im obviously new to cars im asking for questions i know im a noob no need to bust my balls some advice would be greatly appreciated.. so if this motor is fine for me to turbo like you have said since it has a plug.. then sweet unless use have some advice for me that would be apprecaited as well man.. i just want some advice im new to cars
in genreal any bit of advice i would appreciate im new to cars..
for thr 1st question does anyone know if its an A8 ?
i know im a noob lol sorry to bust balls just a lot to take in
cheers
You've mentioned A8 a couple of times, what is that about?
You can certainly turbo your engine, you just need to understand the turbo oil and water plumbing, intake and exhaust to suit, ECU, injectors etc.
Depending on the block it can be harder to do a twin cam conversion because some blocks don't have the machined flat surface for the second tensioner required for that, but it doesn't sound like you were thinking about going that way
On 03/02/2022 at 9:58 PM, GTSBoy said:
And if you turbo an RB30 in front of an old RB30 NA manual gearbox.....the gearbox will not last long. Even at lowish boost. Too much torque for the poor little thing.
It's like catching a 50 pound Murray cod on 10 pound line, the thrill of holding it all together is all part of the enjoyment of the sport! 🤣
  • Like 1
  • Haha 2
cheers
Definitely not an a8
They were vl turbo only.
Doesn't matter.
So judging by the photos you've got the turbo oil drain point (so don't need extra fitting on the sump apart from if you run a head drain/catch can drain (would recommend both), run your 4an oil feed from oil filter housing, coolant feed is probably there too but need to see more photos of the hot side of the block under the exhaust manifold to confirm.
The trickiest part is the provision for the additional timing belt tensioner probably not being there and potentially being the non machined version (there seems to be a few variations in this area).  Mine was a rough cast block so when I was gettig my block prepped I got my machinist to machine down an area about the size of a 50c coin and then made a spacer the same size to bring the level up to flush with the other mating surfaces on the face of the block.  A bit hard to explain without photos...
Either way, ANY RB30 is useable with a little more or a little less work required depending on the block.
  • Thanks 1
As he isn't putting a 25 or 26 head on, so tensioner area is not a  concern in this case.
Should really do an LS swap instead!
  • Thanks 1
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
