Hi guys,
New to the site and getting to know people along the way.  Not that mechanical savvy but willing to learn as I go.
Recently purchased a 1999 R34 GTV that we are going to turbo.  Have been looking at the Haltch Plug & Play in the Platinum Series and the Elite series.  Only issue is they are supported for manual transmission only.
For those with automatic transmission what options did you go for in the Haltech range....or is there a work around for it.
Looking forward to see what people suggest.  Thanks in advance!!
https://www.sau.com.au/forums/topic/483778-haltech-plug-play-r34-gtt/
On 6/19/2022 at 7:44 PM, R34GTV said:
Haha that’s what my partner said also. Not keen on that option lol
It is by far the best thing you can do.
You pretty much have to, by the way. I can explain it in longer words if you like, but put the manual conversion BEFORE you consider a turbo kit in terms of "Things to do".
Haltech can control the auto gearbox now, its just the time it takes to program the logic and get it right. This is no small job as its something that most people have not done yet.
On a mates r34 gt auto we just went with a nistune board flashed gtt firmware and have a adjusted it with no issues. There was a bit of wiring to do with diodes and adding for boost solenoid.
  • Thanks 1
Plug and play was the requirement here. I don't know if the GTV gets the the turbo gearbox or the N/A gearbox. It'd matter, because a Nistune would/could work if it used the turbo auto box.
All of this thinking should be dedicated to going manual though. Including all of the ECU budget and the turbo budget.
  • Like 1
Just another option.
Nothing is ever plug and play. Always something to wire in and most people don't have the skill/knowledge to undertake the job.
  • Like 1
This is what haltech has come back with. It can be done. Just requires some fiddling about.
Once we get all our bits for the GTV and firstly finish off our other car as it’s currently getting upgraded too with more go fast bits will keep you posted with the build. But the way it’s going the GTV might get done before the other car haha.
  • Like 1
It is relatively* straightforward. I have had to wire the standalone TCM and if you look at the modules, all of the wires that go into the NA's standalone TCM are labelled the same as the ones that go into the GTT's ecu. Same number of pins, same labels on all of them. As far as the wiring outputs and inputs go, they are the same for the GTT and the GT.
In my example I was wiring them into a dedicated transmission controller that was external to the engine ECU, but as Haltech say it would not be impossible to wire them into an aftermarket engine ECU that has these outputs. That said, you can wire the NA auto into a GTT ECU and Nistune it given you do not have huge power goals.
And again, all that said, all this time, effort, money and such is a waste because the car is about twice as enjoyable with a manual in it. You will regret spending the money and time on the auto. I promise. I'm only saying it now so I can say I told you so later. I need you to know this, so you will be like "fk, should have listened to that guy"
  • Like 1
I appreciate your knowledge and opinion. 🙂
Not sure how crazy you want to go with the build, but you could pop in a DCT box or ZF box from a BMW to keep it auto then run a GCU wired back into the Kebabtech.
This is what you end up with, insanely good, no knocks/bumps like a manual sequential box and if you want you can actually setup a transbrake:
  • Like 2
On 20/6/2022 at 2:30 PM, r32-25t said:
Jem have made an auto transmission work with a haltech, not sure if it was a nexus or an elite but it can be done
They did my Stagea with the tiptronic auto and I can say it runs very well and shifts great
That is awesome to hear. Did they use the original ecu along with the new one. Or just new one all together and wired it up to the auto box?
The original ecu was completely removed and a Haltech elite 2500 was put in
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
