Hey everyone, I was doing some research to see what type of lights which housing uses and my understanding is the Xenon housing uses D2R lights and the non Xenon uses H1 lights.
do I have my info right?
I only ask because I’m looking to get different housings to make custom lights and can’t really find anything specific enough!
thanks in advance!
https://www.sau.com.au/forums/topic/484081-s2-xenon-vs-non-xenon/
Well.....yeah. I mean, the xenons clearly use HID projectors (of which D2R is a specific type, and I don't know if that is the type in the S2 headlights) and the non-xenon headlight obviously use halogen bulbs, and it is reasonably likely that they use H1....but they could also be H3 or H3C or maybe even H7. Again, in this particular case, I don't know exactly which one they use. The R32s, for example, have used multiple types, H1 and H3, over the years.
There shouldn't be any confusion for you between what main type of light source is used in the two types. One is Xenon (HID) and the other is halogen. It only comes down to exactly which bulb type is used in each, which should be easily findable (for the halogen) and hardly matter for the HIDs. If you're going to make custom lights, you're not going to want to pay the money for HIDs and then gut them. Surely you're most likely to start with plain jane ones.
D2R bulbs are designed for HIDs in reflector housings. There is a shield built into the bulb to help it be compliant with the local design rules. My LS400 uses those. Looking at the C34 Stagea factory HID housings they are reflectors and will call for D2R bulbs. They are pretty annoying in the sense that reflectors are not simple to do an LHT or RHT conversion for. My LS400 also requires one of the low beams to be dipped significantly to avoid excessive glare as the reflector design is not exactly ideal.
If you're going to customise the housing, why does it matter? I'd get halogen ones and retrofit HID/LED projectors in there.
If you have D2R (xenon) headlights, bonus would be the HID ballast (so you throw in D2S projectors and away you go).
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
