Hey. A 10 month old ongoing overheating problem thats just pushed me close to breaking point.
33, S2, 322kw. Nistuned with all the usual mods an unopened engine would need for those numbers. Was tuned & went ballistic for about 12 months. Then about 10 months ago picked up a pinhole in the Chinese rad Id had it on there for a couple years & it was 2nd hand when I got it so I wasn’t surprised when it finally let go. Car got a little warm, not boiling but around 3/4 on the factory gauge. I wasn’t far from home so no problem I thought. I shopped around for a decent new rad I was targeting Mishmoto but at the time Covid supply chain issues & container ships stuck in Panama canal there was nothing decent in the country so I ended up getting another cheap Chinese one from redline performance with accompanying twin thermos. Chucked it in wired it up bled it out 1st drive & started warming up again so straight home. Thermostat I figured. So got a new 1 chucked it in & no change. Water pump I thought next. New one in still no change, sits at half on the gauge for 30-45 minutes no problem . As soon as I leave my driveway temperature starts going up. Needed a break from it so I parked it up for a couple of weeks. Next attempt I started her up & for about 10 seconds it was down on a cylinder then quickly came right, narrowed it down to cyl#4 only for a few seconds after the first startup after sit a few hours. Same time I noticed some tail pipe steam. So head gasket I thought. A few months later I got a Tomei 1.2 thick, arp2000 studs, all the other bits Id need & whipped the head off sent it to get tested dipped & skimmed. Bolted it all back together & today started it up bled the air out it sat & idled held running temp for 30-45 minutes as soon as I left my driveway the f**king c*nting sl*t started heating up again.
Any ideas anyone?
https://www.sau.com.au/forums/topic/484132-overheating-25det/
17 minutes ago, Dose Pipe Sutututu said:
Avoid eBay radiators, including the eBay ones sprayed Mishimoto on them.
Get a PWR or Koyo or so.
Also did you bleed the system properly?
Do koyo flow water around & though the whole rad or does the water fall straight down from inlet to outlet?
That's a "twin pass" radiator, there is a divider in the centre of the core forcing water to go to the other side before it can reach the exit.
Much more expensive design, if a radiator has that it will say so
I'd say the biggest issue will be the 2 cheap fans on it that came with the radiator. Ditch them and get the factory clutch fan and shroud on. The cheap stuff doesn't move enough air.
The only electric fans worth putting on are either spal or maradyne. In 14 or 16 inch with proper shroud.
I use cheaper radiators but always use factory fan or the mentioned electric ones with no issues.
  • Like 5
Robbo's on the money here.
I missed the part where you're running the twin thermos. In the bin they go, factory shroud and fan then see how you go.
  • Thanks 1
I'd be looking for constants between before and after the head gasket fix.
Given what you described which was quick to overheat once you start driving ? not extended drives ?
It sounds more than a fan / rad issue to me.
You could have the FFP leaking into chambers, also sad to say an issue with the block.   The cooling system could handle what ever small leak you have once you rev/drive it creates pressure and heat.
If you haven't already, pressure test your cooling system.
  • Thanks 1
Havnt been on an extended drive because Im sure it would keep getting hotter. Havnt pressure tested it yet but yeah I’ll have to. I was wondering about the plenum leaking coolant, could that cause the steamy tailpipe? Hopefully because Ive been trying to push the block issue to the back of my mind but the steam keeps bringing that thought right back to the front. The only thing that seems to have changed after doing the HG is the miss at startup, which I figured was from water seeping into #4 overnight & looking at the old gasket kind of confirmed it. Appreciate your input.
Appreciate everyones input
Edited by darkoh69
More info added
9 hours ago, Milkmun said:
Do you have a water temp gauge or consult cable to see the temps also?
Only the factory gauge & the digital readout on the fan controller in the engine bay. Seen it a touch over 90 degrees C
Edited by darkoh69
Very much yes.
Make sure you have all the hoses in the correct configuration too, I have seen people plumb coolant line into a vac line in these intake conversions before.
  • Like 1
Plumping configuration should be ok I put the ffp on a few years ago & its been on the dyno twice since then. But when I was putting it back on after the head was back in I could have nicked the plenum to head gasket. It would be just my luck to fix a problem only to cause another problem with the same symptoms. Ive got a new aeroflow 14” fan coming today the twin 10s are really the only thing that’s different in my setup & probably the easiest job to check off the ‘possible cause’ list.
no offense, but that Aeroflow 14" fan won't be moving much air either.
There's a reason why plenty of circuit racers with shit box Skylines (mine included, massive shit box) predominantly use the OEM shroud and OEM fan.
  • Like 2
None taken. I hear what your saying. I know the clutch fans are good but unfortunately the blades on my fan bowed & chewed out the radiator not long after I got the car. So Ive had a 14 inch elec on an alloy rad ever since. It was all I could scrape together at the time & didn’t let me down for quite a few years. But when the old alloy did fail the only thing Ive put on there thats different is the twins. Pressure test has held 1.1 bar for 30 minutes now, is that enough pressure to test it with? What possible causes could that remove from the list?37DD9B09-55DD-4A9F-8B77-5E7902B2221E.thumb.jpeg.4267f6ae91f3f34678de3dd2bb6004a0.jpeg
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
