looks like the drifting could be over and i might have to bring my newly aquired fun car
1976 mini yea baby its getting a paint job (green) and VBSLAB nuber plate, i couldnt get vbbrick plates
of course i could cum to my senses and bring the gtr but i doubt it
if you have ever seen a mini drift you have to cum to the track day cause it will happen
pete
  • Replies 234
fatz..........What ...your getting an R31, GTSX thingy.
More info pls. I luv R31s. Whats it costing you to get it here?
My old R31 got KO by some clutz who decided to turn right from the left lane right in front of me. Im thinking mid way thru this year bringing in an 86 model, no compliance etc. Can you offer any suggestions?
r31 gtsx
86 model fulsik going to be my race car. dont know if ill comply it depends on condition cause if it is hell shit it will become a permanat track car eg roll cage big turboect
you shuld get one they r pretty cheap
only time will tell the final price though
pete
Update,
Venue: Eastern Creek
Date: 19th DECEMBER, 2002
Time: Arrive at 8:15am to be on the track by 9am
Cost: $140 (if more than 15ppl)
$145 (if less than 15ppl)
Participants:
1. Majanal
2. mrthorpedo
3. Prank
4 - 5. Zane + 1 (only 95% now)
6. Roy
7. Kel and Duncan
8. Bonkers
9. Brendanf
10 - 15. Sebaz + Friends
16. Julian GTS-t
17. Roy
18. fatz (Pete Carruthers)
19. gonads
20. 2rismo
21. Roy's mate
22 & 23. Mick & Paul
Maybe's:
Merli
Zane's magna mate. (moved into the 95% bracket)
Oz (95%) Come on buddy! (now back to 50%)
XrSiSt (100%) as above (has day off but not sure if will drive)
Raider
Urmine
Croat
Red900ss
Nissaner
AlexR31
If your name is on the confirmed list and shouldn't be than please let me know.
Cheers,
Dan.
P.S. It is only 9 days, 11 hours and 10 minutes till I get to try to KILL my tyres again... and the best thing is that I'll have a spare set this time!
Originally posted by PranK
you will be able to terrorise me too - i'll be going slow as! :D
Of course, you're driving a 180:lol:
(Just saving dino from having to respond....)
And Dan, "7. Kel and Duncan" should prolly say "7-8. Kel and Duncan "
Originally posted by fatz
anyone joining me in duel hellis on the grass
pete
I have seen footage of last time - aaahhhhh brings back memories.
Pete your olds prolly never told you this but you are different !!!
Prank - as Duncan says - brakes will only slow you down - only 5 minor applications in 3.93klm - no problems.
what is the latest date to confirm
interested in a few mods b4 i attack the track
i will be there no matter what, racing or spectating (i mean pushing ppl out of gravel traps :D
Originally posted by Majanal
Update,
Participants:
1. Majanal
2. mrthorpedo
3. Prank
6. Roy
7. Kel and Duncan
8. Bonkers
9. Brendanf
16. Julian GTS-t
17. Roy
19. gonads
20. 2rismo
21. Roy's mate
Maybe's:
Merli
Raider
Urmine
Croat
Red900ss
Nissaner
AlexR31
Cheers,
Dan.
No need to wait for the mods, you'll just end up hitting the gravel traps harder:D
/deletes all above
No need to wait for your mods, you'll still have plenty of fun in a stocker:D
Update,
Almost didn't put down the most important detail... all drivers and passengers MUST attend a debreif at the Cricketers Arms after the event.
Participants:
1. Majanal
2. mrthorpedo
3. Prank
6. Roy
7 & 8. Kel and Duncan
9. Bonkers
10. Brendanf
11 - 16. Sebaz + Friends
17. Julian GTS-t
18. Roy
19. fatz (Pete Carruthers)
20. gonads
21. 2rismo
22. Roy's mate
23 & 24. Mick & Paul
Maybe's:
Merli
Raider
Urmine
Croat
Red900ss
Nissaner
AlexR31
Raider,
No need to confirm really, if you turn up and want to drive then we can usually find you a spot.
Cheers,
Dan.
P.S. It is only 7 days, 19 hours and 42 minutes till I get to try to KILL my tyres again... and the best thing is that I'll have a spare set this time!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
