Hi new to the skyline and car scene. I just picked up an r33 with a rb25det engine. I need to recirculate the stock bov but I'm at a loss. I've done a fair bit of research on it but can't seem to get my head around it anyone brisbane based who could help for cash or know any shops that could fit me in quick. Cheers
https://www.sau.com.au/forums/topic/484253-bov-recirculation/
BOV is on the back of the crossover pipe. The outlet f that BOV needs to be piped down to the turbo inlet. This is shown in diagrams in the manual, but it's a pretty trivial route. The return pipe is about 1" and runs back under the crossover pipe above the exhaust manifold and then directed into the turbo inlet elbow, facing more towards the turbo than the AFM.
Or if you want to go down the expensive option to "fix" the issue, just bin the stock AFM, ECU, and install an aftermarket ECU, IAT & MAP (if you do not wish to use the internal one).
:D
Talk to me if you need ways to waste money, I'm good at helping with that. @BK also will help you spend money if you need LOL...
nek minnit, has a 2.8L stroker, 6266 to "fix" his BOV recirculation.
  • Haha 1
18 minutes ago, GTSBoy said:
Where's the Samsonas?
apologies, let me try again
nek minnit, has a 2.8L stroker, 6266, twin gates, twin scroll, DCT or Samsonas to "fix" his BOV recirculation.
That combo would actually make a fun car with a good powerband for the street, track, drags (if that's your kind of thing).
plumb into the turbo intake after the AFM. Plenty of places to get the parts around SE Qld- Trix parts, All Import wrecking or jdm garage. Its a 20min job and need a screwdriver and small sockets.
  • Like 1
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
