Been having trouble looking for cams that would be good for a 20e and was wondering if I could use 20det cams in the 20e (yes I know it is SOHC just wondering :))
not planning on swapping the engine, just wanna have some fun with the 20e
  • Haha 1
https://www.sau.com.au/forums/topic/484353-can-rb20dedet-cams-fit-in-the-20e/
35 minutes ago, lucidz32 said:
I was wondering if I could use a single cam from the de in the 20e?
Since there are barely any performance 20e cams available
I'll keep it simple, the answer is no.
  • Thanks 1
No, you cannot. As I said above. A twin cam engine has the lobes for the inlet valves on one cam and the lobes for the exhaust valves on the other cam. A single cam engine has all the lobes for all the valves on the same cam. There is absolutely no way to make this work going in either direction.
  • Thanks 1
rather than worrying too much about cams, what are you trying to achieve and what sort of budget do you have?
you can potentially increase power 4-8% by a freeer flowing intake and exhaust for under $5k
  • Like 1
Hmmm, I am somewhat out of money after doing what you have said above along with a few other mods and just looking for any solution where I can have better cams on the 20e 🥲
Sorry if I seem uneducated, I am fairly new to this 🙌🏼
Cams are unlikely to be a practical answer with no budget. You will need a custom cam ($1k) plus a tuned ECU ($1-2k) and still probably the intake and exhaust mods ($2-3k)
The unfortunate reality is that no budget to modify a non turbo car will result in no improvement (mostly likely outcome will be less power, rough running and bad fuel economy)
  • Like 2
Add turbo, enjoy life. If not turbo, add supercharger. If not supercharger, add nitrous. Anything else will be a disappointment. Remember, the RB20E is a very small, very low torque engine designed to do one thing and one thing only. Which is to move cars from point A to point B at the lowest possible speed while minimising Japanese registration tax.
  • Like 1
10 hours ago, lucidz32 said:
What bad luck, imma end it with these words "my engine blew a few minutes ago" imma 25 swap it when I have enough money 🥲🥲
Word of advice. If you're a younger gent, don't try to speed up the process by buying cheap ching chong meow ebay parts. Try and find the best bang for the buck and if it takes time, it takes time.
RB20's have creeped up in price a fair bit but would also be a cheaper option then an RB25. They are fine for 300-400whp. Cheers.
  • Like 1
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
