Is it bad when you haven't driven your Skyline for so long that . . . .
11 hours ago, r32-25t said:
I will never let mine end up unregistered
Can you keep it registered if it doesn't run? Or do you have a hard deadline to get it running again before the pink slip is due?
It hasn’t run for over 2yrs now and I’ve kept it registered the whole time just because I don’t want to go through the drama of trying to get a blue slip
my hard deadline is all Japan day
  • Like 3
On 02/02/2023 at 2:47 PM, Dose Pipe Sutututu said:
Need mmoaaaarrr M3 Eurotrash as everyone here calls it.
You'd get rolled for sure.
Having an Asian car, they think you're part of 5T or something :P
LOL... show them my non-existent dragon tatt on my back and my non-existent tiger tatt ono my chest..
dumaaaaaa
  • Haha 1
nah, they all drive mercs, BMW or Audi's....it's a status thing!
  • Haha 2
Oh those hoses under the manifold are spectacular to change !
Changed out the heater hoses on the drivers side thinking they were cactus . . but its still leaking.
Made up a bass T piece with hose barbs and soldered in a car valve extension, plumbed it into the throttle body coolant line, filled up the cooling system, put on a tyre compressor and pressurised it and . . . . found the leak !
Its the short 2 inch piece of hose that comes out of the block . . . . above the started motor . . . . so you cant get to it from above . . . soooooo . . . its out with the started motor . . . again . . . . to access it from underneath . . . . went and got a piece of 19mm ID hose that will take about 20 billion pounds of pressure cause I aint doing this again
Hahahaha. I'm sorry for laughing but exact same thing happened to mine about 6 months ago what a prick of a job that was. I wish you all the best. :1_grinning:
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
