(context, my rb25det pull type gearbox was making a grinding sound on idle and when accelerating in the lower rev range but goes away with the clutch pedal in) I got a pretty hefty bill recently which I'm not overly happy about (only because the problem is still there), my mechanic told me a while back that the grinding noise I had in my car was the spigot bearing, long story short but he pulled it out and it looked like brand new, he said that it wasn't lubricated and ended up putting in a new one that was. I didn't think much of it, until I turned on the car went for a drive and noticed the car has the EXACT same sound, nothing has changed.
He said it had some noise which I have no idea what he's referring to and I told him that my gearbox was still grinding, when we went for a test drive he said it was normal. There's no way a grinding gearbox is normal. You can really hear the grinding if you're in a higher gear but your speed is low, I guess makes sense as the gearbox is working harder.
That's one issue, the other issue I noticed is there is a loud rattling sound especially when I start up the car and especially as I go up my driveway. Some other things to note is that the previous owner did a dodgy clutch install and also stripped one of the threads on the flywheel bolt which my mechanic all fixed up and put a new clutch kit in, which I'm not sure if that has something to do with it. I know a bit about the history of the car, it was definitely thrashed and tracked.
The car itself drives fine and doesn't crunch through the gears, there was wasn't much metal shavings on the gearbox. Do you believe my mechanic misdiagnosed my car? I'm trying to decide what next steps to take, I imagine I'll have to rebuild my gearbox eventually.
Edited by silviaz
https://www.sau.com.au/forums/topic/484997-did-my-mechanic-misdiagnose-my-car/
I don't think you can blame the mechanic. He replaced what he thought and what is a common source of gearbox noise. It could be internal gearbox bearings that are causing your noise. Would have been an even bigger Bill. These boxes are a little noisy at low revs high load. I had a brand new one in mine before I broke it and it also had noise at low rpm.
I'd just put up with the noise and don't load it up at low rpm. Gearboxe is trying to tell you it doesn't like it.
  • Like 1
9 hours ago, GTSBoy said:
Input shaft bearing, more than likely. More common on the skinny box, but still an issue on the fat box. Mine does it (groans and resonates at low rpm in higher gears).
Funny thing is I wanted that replaced but my mechanic said it's a rebuild at that stage, I wanted that replaced because from what I understand it's not deep in the gearbox.
Yeah, problem is would have been better to do it all at once but now I have to pay to pull out the gearbox again.
Weird to me how the mechanic didn't offer to just tear into it further at that point but that's just how it rolls with a lot of mechanics. They'd rather get the cashflow sooner than later.
Well, replacing a front bearing is not a "rebuild", nor does it trigger a need to rebuild everything in the gearbox. A dismantled gearbox with worn/aged parts can be put back together just fine. The only argument is whether the labour to do so is then considered to be wasted compared to doing a rebuild as well.
Nah this mechanic is honest and for him he has a more "leave it if it's working" approach. Not always ideal because if for example I didn't replace my rear main seal and it leaked then I'd have to pay him again to pull out the box.
Yeah that's what I thought, I thought if all he has to do is take off the input shaft cover and replace the bearing behind it, that sounds like a pretty easy job but I'm not 100% sure as I haven't been able to find much information on the process.
No it’s not that easy, you need to completely strip the box in order to get the input shaft out and press the bearing off it and press the new one on
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
