Hello , im new here and i have A31 home build
RB25det neo stock eng / turbo
aem ems 2 blue connector
aem 3.5 map
aem cas disk
aem wideband connected to ecu
355 lph pump
550 nismo yellow injectors side feed
aftermarket regulator
and won’t start with base aem tuner basic tune
eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle
Now it won’t start
Wideband reads 10 and 11 at lowest fuel setting
and will share calibrations soon for aem tuner i think something is wrong in aem tuner
please if you have any information, am very grateful
https://www.sau.com.au/forums/topic/486463-cas-issue/
6 hours ago, nash47 said:
Now it won’t start
The wideband reading is meaningless if it's not running.
Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that?
Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
https://www.sau.com.au/forums/topic/486463-cas-issue/#findComment-8003487
aem 3.5 map
aem cas disk
355 lph pump
Now it won’t start
Your best and only option is to verify your CAS is reading properly with an oscilloscope (I'm presuming the V2's had a built in one) and then properly sync your ignition and mechanical timing using your offset angle within the ecu. I don't understand why you flipped your CAS.
Edited by TurboTapin
https://www.sau.com.au/forums/topic/486463-cas-issue/#findComment-8003494
I'm going to assume they flipped it, as the timing setup in the AEM is catastrophically wrong.
Once it is fixed, they'll likely need to swap it back to normal.
https://www.sau.com.au/forums/topic/486463-cas-issue/#findComment-8003497
5 hours ago, nash47 said:
This is aem disk setting in aem tuner and still 180 dgree off or ignition on exhaust cycle is it from cas it self as cas seems wouldn’t fit in cam shaft if wrong position and wiring been verified any ideas
Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
https://www.sau.com.au/forums/topic/486463-cas-issue/#findComment-8003644
4 minutes ago, nash47 said:
Yes sir am asking is there possible way from aem tuner from wiring pins
It will be a software setting.
I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on.
If it were Link or Haltech, someone would be able to just send you a ECU file though.
https://www.sau.com.au/forums/topic/486463-cas-issue/#findComment-8003664
Thats what im trying to solve bro
no one with aem tuner experience would advice
much appreciate
https://www.sau.com.au/forums/topic/486463-cas-issue/#findComment-8003716
On 8/9/2025 at 7:56 AM, joshuaho96 said:
Could be falling edge/rising edge is set wrong. Are you getting sync errors?
No sync errors , i have installed AEM disk will return original 360 slot disk and check if there’s any one with running AEM disk could share setup
https://www.sau.com.au/forums/topic/486463-cas-issue/#findComment-8004155
The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this:
305817248-AEM-Undocumented-Settings-v1-2.pdf
https://www.sau.com.au/forums/topic/486463-cas-issue/#findComment-8004169
