i just thought i would start a thread for people to throw up their dyno sheet and a list of major mods so people can compare and enquire what make a good improvement and what doesnt and to see how laggy certain turbos actually do make the ol rb engines....
i have :
lt12 plug in microtech ecu
gt28440hp bb turbo (t25 flange)
600x300x76 modified hybrid cooler
malipassi reg
480cc injectors
bosch 909 pump
3 inch exhaust with custom dump pipe and no cat
adjustable cam gears
profec b spec 1 boost controller
im especially keen to see guys with rb20 engines and turbos like 2530,2540 etc
my graph can be seen here.... http://www.skylinesaustralia.com/forums/at...achmentid=21307
low boost (8 psi) hi boost (18 psi) cheers Jon
https://www.sau.com.au/forums/topic/49209-post-up-your-best-dyno-graph/
  • Replies 223
Posted Images
My R33 is still pretty stock but i have dyno figures for it.
it has-
- a front mount intercooler kit by Hybrid.
- a custom made double dump pipe by Drift King.
- a turbosmart boost controller switchable hi/low boost.
- 3 inch exhaust.
it makes max power at 6400rpm at 9 p.s.i.
http://www.skylinesaustralia.com/photopost.../cat/500/page/1
heavily modified (engine just been refresh when the turbo and cam shaft fitted)
Apexi RX6 high-mount turbo
Apexi exhaust manifold
Apexi external wasgate
Apexi cam shaft
Apexi valve spring
Apexi fuel pump
Apexi injector
metal head gaskit
ARC front mount intercooler
Full trust exhaust system
Blitz dual sbc boost control
z32 air flow meter
Just Dyno the car at Dyno source and it made 392hp at rear wheels in 1.3bar(pump fuel)
should make 430hp at rear wheel in 1.4bar with race fuel
on the dyno graph still show car run very rich at 392hp at rear wheel in 1.3bar.
This is my current set up, im pushing my injectors a little though, need bigger injectors
gt2535 turbo
600x300x76 hybrid cooler
bosch motorsports fuel pump
Bleed valve boost controller
215rwkw on 18psi
Dyno paper i will post as soon as i can get it scanned
I saw merli's 600.1 rwkw graph...but he claims to have "lost" the pic now.
here is mine from the SAU Dyno Day today :(
Apparently it was running too rich, so we should be able to get the extra .3 rwkw with some tuning :D
I'd love to know Paul's secret to 450HP. I'm nearly there - with similar turbo (larger rear housing). Dude did you have an exhaust on your car when you got the 450 ?
This is 23 PSI - ( get no difference in power from 21 PSI upwards - tried 25 PSI today and 2 rwkw less - same dyno)
GT30 is pretty ambiguous as to the size of the turbo, the GT30 family is huge. Then again, it could have a '30 rear, and a larger family compressor. Such mystery!
ps. 450 hp is 335kw, different dyno could accomodate such variation.
Edit: You can't compare the A/R directly between Garrett vs HKS - different designs where the HKS units have a smaller radius ®, so the area (A) could be the same on a larger HKS vs smaller Garrett.
Edit2: You would probably find that you can drop the size of your turbine housing B-Man and not lose horsepower.
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
