Rez's R32 GTS-t Type M... presentable version!
  • Replies 322
nice nice rezz! ask for cooler pics and you have one on every angle. :P
like ronin and shan said, i removed that vertical support in order to fit the cooler. i used two horizontal homemade supports as you can see. im guessing that your cooler is fit for the 32gts-t right rezz? coz yours is a really a neat install. was unaware that that na's didn't have it? how does the bonnet shut without it?
thank roy. but its a trial bar, from japan itself. www.trial.co.jp click on products and aero parts. beware the modified version of the s15 trial bar thats been fit to the r32 that everyone's calling the "trial r32 frontbar" here in aus. posers.
technically speaking it is a TRY FORCE Aeropart, they sell through TRIAL.
Aaah *cough* yeah... :P all the parts I buy are "for HCR32"...
Your 'cooler isn't?
During the week I recieved a huuuuuuge box from Bomex with an HCR32 front lip spoiler:
A huge box for only this:
I also got a Nismo rear spoiler from East Bear:
Not wanting to fork out for labour, I went onto the roof of my building to spray the front lip spoiler (the Nismo spoiler was painted already by East Bear by request)
Ashiya and surrounding suburbs:
Dummy fit:
This thing was top notch quality!!! Hell, it was such a snug fit, I could've driven around without screwing it on properly. Well done Bomex :P
So much downforce on the back, I'll never get the tail out now!
I bought the car with that crease just in front of the left front wheel.
hwo much did the front liip set you back in $AUD? is it legal? what is the legal ride height in japan? is there one at all, considering those crazy p-van things!
also, where can i get that sun deflector from? my mashimaro one is starting to fold...
edit: rezz, give us a straight rear shot. is it the same lip that sometimes goes under the oem gtr spoiler?
Well done mate, looks good :P.
Just spoke to Justin right now and he will indeed need to take care going up/down carpark ramps. I already scrap ramps whens my car was about 14cm from the ground, now 12cm from the ground. There is a legal ride height here in Japan but not greatly enforced.
The Bomex front lip spoiler cost about A$190 (13,000 yen) from Bomex Japan.
The sun shade cost 200 yen (A$2.50) from SuperAutobacs in Itami... incidently the place where Ikeri works :(
Btw, coco69, I'll post up a rear shot tomorrow. The front lip is a dedicated HCR32 "aero bumper" spoiler, it doesn't fit R32 GT-Rs.
rezzeh, did you use nissan 738 paint or didja use bumper paint (the one that gives it a nice bumper like texture?) lookin good... now get yourself some sidey's n rear aero.
ride height over here is 10cm i believe but unlike australia here they measure it from the actual car body not the bodykit. u can have the plastic kit scraping the ground just as long as the metal frame/body whatever is 10cm high....i think..
I talked to Justin last night or rather was over his place to check the fine work he had done preparing and installing the bar.
It looks great as it is, who needs sideskirts and a rear bar...go the JGTC look ;)
As the car is to become a dedicated track car not some show pony :P
The sun shade cost 200 yen (A$2.50) from SuperAutobacs in Itami... incidently the place where Ikeri works :P
Thanks Rezz for that, you've given me an idea. Perhaps I could paint the lower part of my front spoiler black.
    • I have wasted too much time on this, more than I am willing to admit. I hope someone can set the record straight for me.  I want to replace my Nismo (non GT pro, non GT) standard 2 way in my R33 GTST with a 1.5 way... Ideally I want to get an ATS 1.5 way Carbon LSD, but I don't want to reuse my 29 spline 5x1 axle stubs, and new 30 spline 5x1's are impossible to get a hold of ($$$), and I don't want to drop the cash on going to 6x1 stubs and axles ATM. Which leads me to the Nismo GT Pro 38420-RSS15-B5 or RSS20, as they come with new axle stubs meant for the diff, and is "Convertible" from a 2 way or 1.5 way to "Other ways", but that is where I am stuck as the documentation is a bit all over the place.  To sum up what I have found I believe the all the Nismo GT Pro PN's are convertible from 2 way, 1.5 way, and 1 way; but Nismo sells 2 skus (2 & 1.5) so people do not have to disassemble to convert it.  I found this thread on 350z but it left the question unanswered. https://my350z.com/forum/engine-and-drivetrain/620032-nismo-gt-pro-lsd-1-5-vs-2-way-and-torque.html  Essentially the way I think it all works out is like follows...  2 way  1 way  and 1.5 way would be the center pinion shaft in the 1 way block, but with the with the center flipped 180*. So the ramped side of the pinion would face the 1 way gate and act like a ramp.    I can only get my hands on the 2 way in the states, and I am not trying to get stuffed on tariffs by ordering from Japan or anywhere else. I want to confirm that if I get the 2 way I can convert it to the 1.5.
    • Hi everyone, I have purchased my first GTR and I want to do a single turbo conversion to it. I've been doing as much research as i can and there are a few things that I can find and need to know. I need to run a coolant feed, coolant return, oil feed and oil return for my turbo setup. Here's what I know so far: On the hot side of the rb26 there is coolant feed, oil feed and oil return. Coolant return will be going around the front of the engine to where the thermostat is located. I will need to block off the rear oil return port. I will be running a turbosmart boost solenoid so any of the factory boost stuff wont be needed. Now onto what I don't know: 1. What do I do with the coolant / vacuum hardlines that run around the back of the motor?. 2. What do I block off or loop or move or remove?. I will be running the OEM intake manifold. 3. Is there anything in particular I need to buy for the cold side of the rb26?. I already have the intercooler and pipes sorted. If you have any pictures or information it would be appreciated. Thanks....
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
