Don't nominate a time for the day - say like 2mins or something. That way you'll be put into the 'not been on track before group' and you can go as slow or fast as you like to begin with in the morning. If you get faster, they'll move you to a faster group for the arvo. Simple, and that way you'll have no arseholes running up the back of you to put pressure on you.
Won't have to do numbers - Maserati will supply your car a number, and you'll have to stick it onto your car. Any existing numbers will not be read anyway.
I had Michelin Pilot Sports on my last car when I went to sandown last. Had alot of beading, but didn't use much tread. Can't tell u about semi comps... but I imagine a set of semis should last 4 - 5 track days?
  • Replies 409
I have filled out the entry form for track day and will fax it in on Monday with TBA in all CAM related fields. Hope I get in. On the Maserati Club entry form it states $125 for the day (Roy's original link), Nissan Datsun entry form (snowman's link in VIC section) it's $85.
different track events mate.
LOL...i nominated my time at 1:35, which i hope is about 5 seconds off what ill be able to get. If im nowhere near 1:30s then it will be proof that i cant drive for sh1t cause the car should be capable of thos times :uhh:
Snowman, what sort of dollars did you pay for the Ferodos? The WA guys have some Hawks going for $275
Yeh, I'm trying to get some Endless ceramics... but can't get Brent from Nengun to reply to my emails :mad:
What are a set (Front) of Ferodos worth, and which ones exactly? :)
PS Troy, you've got me down for 2 of them bonnet straps right? how do they attach to the bonnet?
Ferodo 2500s...and its only the one strap. Ill have to run around and check a few ppls cars, as the proper ones ive made have been for an S14 and R32 GTST, the dodgy ones that worked a trick at PI are basically universal, but werent the most elegant solution.
Thanks mate, you know mine is a 32R right?
And I need 2 - one for my mate's Integra Type-R too :mad:
Cheers - want me to wire you some dollars?
Yeh why not, how much you offering? If i put a Nismo badge on it will you pay $350?:mad:
Dont worry about the coin, its all good, on the day is fine. Towards the end of the week when we have numbers finalised ill do a quick head count and buy all the parts in one hit
Roy/Ronin - Ferrodo 3000's were $280 for a set of fronts at racebrakes.
The 3000's are basically the track only ones (cause they are too damn noisey otherwise) where the 2500's are the street/track comprimise.
Adz - unless you get some cheaters then 1.35 is probaly right. Infact damn good.
Oh hang on - your driving a RWD car. Sorry I forgot - you guys should be running the flat 1.20's thats right cause they are so much better than us poor blokes with 4wd.
Do they grind at all when cold, are they eating the rotors after the 4 track days. I ask because a friend ate a set f Harrop rotors using pretty hard core Pagids:(
Your finally coming around to our way of thinking :freak:
Its ok guys - we all know we only get 4wd cars to cover our short falls as drivers.
I mean anyone can drive a GTR fast. Roy tells me there's no skill at all in it anyways.
But then Roy also tells me Sandown is just a drag strip (with 12 corners in it!!?) and that there's no reason a GTR should be quicker around there - just like there's no reason for them to be quicker around the Island - so we'll just have to wait and see.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
