  • Replies 148
Posted Images
Are the bosch ones like the Nissan/Splitfire ones or like a lead/distributor sorta setup?
UMMM yeah
I dont know the way it is set up is that the coils are mounted on the rear firewall and the ignitor has been move to sit underneath the Coils and then just run 6 leads to the spark plugs directly from the coils
Its coming from the side of the coil. Does this mean there is a small crack on the side? You can see burn marks on the side from where it is getting warm from the little leak..
yep means theres a crack, tape/glue it up and see if it improves
I will be having a look at my coil packs this weekend, as I currently have 4k-5k+ rev problems.
I think I will clean them first and have a good look, and glue them if cracks are obvious.
I think replacing them will be the best option in the longrun.
Will let you guys know how I go.
OK so my mate helps me take out the coils on my GTT. We look at all of them and can not find a single crack or blemish, they all look new.
We tape them up anyway and go for a drive, problem is still there.
So we decide to gap the plugs at .8, SO FAR THE PROBLEM IS FIXED!!!
He reckons it will be fine from now on, I hope he is right.
hey guys.. just wondering if urethane would be better than the araldite glue..
does anyone know?
Hey, It all depends on whether urethane is heat proof and has good electrical insualtive qualities.
Basically you need to insulate the coil packs from arcing if there is a crack in them.
Use whatever, as long as its heatproof to about 130 deg c and is an electrical insulator.
Chris :)
well i did it, i just used a razor to apply a liberal coat onto the front of it where i saw the crack (only 2 had cracks, and 1 had a burn mark)
.. im going to leave it for a while to dry.. heres how they look now..
ill post results later.
i just stuck them in and now its running alot better.. its still early to tell if the urethane is reliable or not but so far its looking the goods..
it costs around $18 a tube for the urethane.. im just not sure what the heat resistance is.
ive had the same problems, but in the end im purchasing new coils, they are not spitfire ones. This guy in NZ is selling them cheap and provides a good spark.
http://gdz1la.kol.co.nz/
i have purchased it and yet to put it in, but the feedback from customers is great. No more missing at idle or revs.
tried this with alrodite (how ever you spell it) still got 5k missing problem, have to bite the bullet and get some spitfires i think.
Hey, Have you checked your spark plug gap?
What boost and mods U running?
Just curious...
Haing a look back in the thread, it seems that most problems are either cracked coils or bad spark plug gap. If it wasn't this then it was fuel problems.... like fuel cut or blocked injectors...
You guy's are Legends!!!!!
My RB25 180sx has been missing from about 4 grand fro ages now. It has been driving me nuts.
I pulled out the coli packs and there didn't seem to be any cracks, so i just taped them up to be sure. That didn't work.
So I followed the advice to pull out and gap all the plugs and also sprayed the small coils under the rubber boot with WD40.
Now the thing is running beautifully again :)
Thanks again! Top thread!
Jeff.
I have done this as well.. Yet to put them into the car.
One other thing I did was get some VHT Engine Block paint (400+ Degs). Taped up the electrical contacts and the very stem of the coil. Then gave them about 5 complete coats each.
Now I know that every possible section of the pack is coated one way or the other.
did the vht engine block paint on my coils (fire red). Seems to keep em cooler and works great.
The only problem is they take a long time to dry.
:P
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
