Discount prices on Bridgestone RE55's for SAU Vic members
Ok Guys, Here's the deal...
Darren (Daz) and myself went down to Donnellan's in Box Hill this afternoon and arranged some great prices on Bridgestone RE55's for all you lucky SAU Vic punters who are looking to buy some semi-comp rubber.
There are two different compound tyres you can choose from with the RE55, the SR or the TT. The difference is the TT is a softer compound, which is stickier around corners, but will wear out faster. The SR compound is recommended for getting more life out of the tyre, while still providing strong grip on the track. The price is the same for either compound that you choose.
These prices are currently available as single purchase, just make sure you mention you're from Skylines Australia. The group buy I was planning was too difficult to coordinate logistically, and the prices wouldnt be much less anyway, as these are already low prices..
Details:
Contact Person: Paul or Mark
Donnellan's Box Hill (Bridgestone Tyre Centre)
837 Whitehorse Road, Box Hill
Ph: (03) 9898 9591
Melway Ref: Page 47 B9
UBD map ref: Page 256 N14
Prices:
[ 18" tyres ]
Bridgestone RE55 235/40/18 . . . . . . . $354 per tyre
Bridgestone RE55 265/35/18 . . . . . . . $392 per tyre
[ 17" tyres ]
Bridgestone RE55 235/45/17 . . . . . . . $347 per tyre
Bridgestone RE55 255/40/17 . . . . . . . $363 per tyre
Comparison of tread pattern between older Bridgestone 540s and current Bridgestone RE55:
These are the best prices I've found, considering some of the other places charging $470 - $530 per tyre(!) for 18" size.
I hope this helps people out with saving time searching for a good deal on Bridgestone semi-comps.
See you on the track :P
-Matt
  • Replies 56
Nice prices
How many km of normal driving are the TT rated at?
Well they're not really designed for street use, but they are a street legal tyre. You can normally get around 8,000 to 12,000km I've been told even as high as 14,000km. Obviously if you factor in the additional wear from attending track days the tyres wont last those many km's.
Nice prices
Well they're not really designed for street use, but they are a street legal tyre. You can normally get around 8,000 to 12,000km I've been told possibly even more, it depends on your driving style. Obviously if you factor in the additional wear from attending track days the tyres wont last those many km's.
Denham, if you need to know how many kays they will last on road, the answer is that you shouldn't be using them on the road!
They will try and kill you in the wet on the road anyway in your beast!
thats bullshit!!They grip well in the wet
:werd: they are fine in the wet. They struggle when the tread depth gets close to the wear markers, but doesnt every tyre?
They are however noisy when driving, and your car can tramlnine a bit with them. If you can afford r-compound tyres for the track you can afford a cheap and nasty 2nd set of rims for them. I like the sound and the car sometimes tracking funny on the road but im an idiot who wishes my car was a touring car :D
Sorry perhaps I should rephrase... compared to a 'proper' road tyre, these will be more trecherous in the wet on the road.
And particularly for Denham's beast, probably a waste of tyre for the road, unless he has buckets of money to throw at tyres :D
:D
I have Dunlop RSV98s... they suck in the wet. But I have a feeling that they suck generally... we'll see at Sandown haha
And particularly for Denham's beast, probably a waste of tyre for the road, unless he has buckets of MONEY to throw at tyres :D
:D
LOL no i dont have buckets of money.
I have some new hankook silica tyres to go on my new 18 inch rims soon.
These tracks days are going to start getting expensive once special fuel and semi slick tyres on a second set of rims starts happening.
DOnt know if i will be running over 300 at the wheels for the first time out at sandown, only prob 260 odd to see how the car/engine holds up.
Semi comps are fine in the wet. Me and snowman had a great time in the rain turning into turn 1 at 200 km/h.
On the road they sound like a plane is going to land on your car and I hate the way they hold onto every little bump, pothole, road angle and white line. The tramlining is terrible. It's hard to relax while driving your car with stickies on a shitty road.
well...semis are only OK in the rain with plenty of tread...they wear quick and you need to keep an eye on them. Once the tread is gone they are exactly like slicks in the wet :)
you really do need at lest 4-5mm of tread for them to work in the rain...
Actually the TT's are the softer compound.... go the SR's, they will last considerably longer...
Is that right? Well.... Paul @ Donnellans told me the reverse... TT was the longer lasting compound. better double check before you buy, I know I will :)
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
