How much are you paying for CTP Greenslip
I'm 23 and in 2216 and haven't lost any points :'( fark meeeeeee for a R34 GTT.
Prices (incl. MCIS Levy & GST) Insurer
AAMI.jpg$404.29 $787.99
Allianzlogo_auth.jpg$403.00 $787.00
CIC-Allianz $396.00 $773.00
gio.jpg$401.51 $782.30
nrma.jpg$403.53 $788.07
QBE.gif$397.00 $774.00
zurich.jpg$401.00 $783.00
Thank you for using the MAA's Green Slip Calculator - our free 'one stop' service to help find the best Green Slip price for you.
Edited by MrRx7s3
By the way just a little off topic, does anyone know of any other insurers that insure imports and under 30 year olds apart from just cars insurance and the ohh so lovely shannons that want $4868.72 to insure my r34 gtt at $16000 haha lol.
Hah - GIO wanted $782 for CTP for the Lancer. No thanks - Shannons for $626.
still annoying though
Funny - you'll notice on your statement that the $$$ paid out to Shannon's goes into a GIO account anyway. * cough
Exactly, so I wonder why GIO wants the extra 160? plus the extra on top for not having to deal with a subsidiary.
BAH
Because the Shannons CTP is conditional. Not everyone can get one. Kinda like a members only price ;)
The government needs to stop increasing CTPs, I am trying to figure out how people on a lower income bracket can afford this. I'm imagining loads of uninsured/unregistered cars out there.
When I was at uni, I remember CTPs being $300 and that was crazy expensive, I wonder how students these days can afford $~770 + rego + pinkslip + insurance.
Saying that, last year it cost my accord more for CTP than the Skyline. Makes no sense?
Plus faked crashes resulting in faked injuries in SW suburbs of Sydney - assuming that 2010 reporting was correct.
Yep. Last 2 years there has been a 25% increase in ctp claims. That's a big increase.
All those bloody "compo payouts"
Orthopedic Surgeon:- Now Mrs Scam, show me how far you can lift your arm!
Mrs Scam:- Just up to here (hip high) doctor (struggling).
Orthopedica Surgeon:- Are you sure you can't lift it any higher?
Mrs Scam:- That's as high as I can go doctor.
Orthopedic Surgeon:- Well in that case, show me how far you could lift it before the accident!
Mrs Scam:- Right up (to the shoulder) here doctor.
:whistling:
:whistling:
:laugh:
Tried Lumleys SV?
They only do over 30's :'(.
You sure? I got my 34GTT insured through them last year and I was only 25 at the time. They were alot cheaper than anyone else, and had the highest value on the car as well, NRMA only wanted to insure it for 12 grand
:whistling:
ahahaha I can see that actually working
back to my original question, how do less fortunate people afford CTP?
By having such high prices attached to CTP & rego more and more people will drive without rego and insurance. My friend's XR6 got smashed into by an unregistered and uninsured Soarer. That went no where, now he's out of pocket forking out for his own repair bills (as he didn't have full comprehensive only 3rd party).
Insurance said it was up to him to chase up the owner of the car, but that got no where.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
