Any tricks here to stop it ?
Was advised against loktite as links are expected to wear quickly with the big arse bar.
6 sided socket, not 12. ;)
My end links are fine still. I doubt you will need to change them in 10 years if they were replaced.
I filed 2 flats on the shaft (just outside the dust boot) this allows you to hold the shaft stationary whilst tightening the nut. Using low strength loctite won't be an issue if you can hold the shaft
Are you using the OEM style flanged nuts?
The powdercoat may also be compressing beneath the nut if it has been applied thickly; maybe shave it down to allowe the nut to bite properly into the bar itself.
You could also try a nyloc nut.
With anything suspension related, I always do the final tensioning with everything at the running ride height, on ramps is ideal.
Ok getting sick of knocking in the front end.
Can feel it through the pedals.
Tried tightening up the sway bar, but literally comes loose again in a day.
It's the bolts that connect the sway bar to the links.
Used a perfect fit spanner and cranked until the point of snapping it.
Still a faint knocking.
Thinking of replacing the links with Whiteline ones.
But can only find them for WC34 (KLC108)
Yo "wagoneers', my shocks have gone on my ARX. To replace all 4 OEM shocks through Amayama is going to be around 1300 delivered.
What alternative do I have? I don't want to lose much height so I think the BC coilovers are out. Happy to lose max 20mill.
Any ideas on other alternatives?
Anyone know of anyone who's wanting to get rid of their stock suspension? (obviously it'd have to be in tip top nic)
Cheers in advance
Cheers in advance
I thought ARX was higher ride height so different suspension to RS and RX. If so do they make ARX specific coilovers? Otherwise the coilovers will lower the car even at their highest setting. Anyway, I'm happy with the ride, fitment and quality of my MCA blues. I asked the same question about stock ride height and you can do so with the MCAs. Not sure about the rear height with the BCs which are not a coilover but a seperate spring and shock.Yes, I'll keep an eye on my shock mounts!
The sales rep spoke of those but strongly suggested going one step further to the XC spec making me think that Blue's were simply in there to cover market share.
1500 isn't so bad, I assume they'd still be better than stock ARX suspension. Anyone with the Blue's fitted?
I'll follow up with BC tomorrow and see what they can do; if not, i'll go with MCA I reckon.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
