Spotted a white s1 this afternoon on the M2 motorway in Winston Hills, it was heading away from where the M7 stops and becomes the M2 (heading North).
Was it you, Duncan, by chance?
Spotted CL11QE yesterday in his garage, and helped get it running again!
That counts as a fair spotting, before anyone asks, because I AM THE MODERATOR AND I SAY SO!!! :)
Hehehehehe
i want you front lip! i also love your car
Its funny you should say that. I hit a fox the other night and it took a chunk outta my front lip. Spewin!
Might claim it under my insurance, not sure yet though.
I rarely post on these forums, but I came out from the shops today and there was a yellow S2 parked next to me! Armadale Shopping Centre (Perth). Took some pics. ;)
I have seen this one around a few times.
Edited by revolt
Good work Trent good to see you OUT & ABOUT car looked sweet hope to see you on cruise when we set date & map cheer`s chuckie .
hope you took a chunk out of its head !!
so what the name of your front lip ? is it a dolphin or somthing ?
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
