spotted white series 2 on forest rd penshurst, (sydney) round 9ish i guess, white with dayz kit i think, pretty dark and i only got to flash in the last second.
also didnt see any stageas in cronulla tonight!!
SNAP! Well almost...
Lightning yellow C34 cruising down Main North Rd (S.A.) about half an hour ago.
Drove side by side for a bit and said hi (the missus recons i was more excited than a 12yr old girl who had just seen Justin Beiber!)
Very jealous of your dayz kit mate ya got a nice ride there :thumbsup:
Spotted at eagle vale Bp yellow stag 34 with sau sticker at the back. See you again at woodbine
Yeah finaly been spoted only taken a year for this to happen we'll I guess I should drive it more than just sit locked away at home
White m35 at m5 southbound near casula
I think that was me, and you were in a black Honda giving me a huge grin and thumbs up? :P
Had just picked the car up and was trying to get out of Sydney... Desperately...
far out from SA
for sure thats the white stagea from northshore?
far out from SA
Yeah from northshore.
Car is almost perfect, just a couple of little things to "upgrade" :D
Your number plate gave the game away :P everyone else just starred. And yes, Ive had my first Volvo comment.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
