spotted white series 2 on forest rd penshurst, (sydney) round 9ish i guess, white with dayz kit i think, pretty dark and i only got to flash in the last second.
also didnt see any stageas in cronulla tonight!!
SNAP! Well almost...
Lightning yellow C34 cruising down Main North Rd (S.A.) about half an hour ago.
Drove side by side for a bit and said hi (the missus recons i was more excited than a 12yr old girl who had just seen Justin Beiber!)
Very jealous of your dayz kit mate ya got a nice ride there :thumbsup:
Spotted at eagle vale Bp yellow stag 34 with sau sticker at the back. See you again at woodbine
Yeah finaly been spoted only taken a year for this to happen we'll I guess I should drive it more than just sit locked away at home
White m35 at m5 southbound near casula
I think that was me, and you were in a black Honda giving me a huge grin and thumbs up? :P
Had just picked the car up and was trying to get out of Sydney... Desperately...
far out from SA
for sure thats the white stagea from northshore?
far out from SA
Yeah from northshore.
Car is almost perfect, just a couple of little things to "upgrade" :D
Your number plate gave the game away :P everyone else just starred. And yes, Ive had my first Volvo comment.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
