spotted, pulled up and had a chat with a bloke in silver RS4S at townsville strand bout 7pm today, just moved up here apparently, looked like a nice example. and both of our missus' said they same thing hey look another one :thumbsup:
im on my way up to sydney tonight for a couple of weeks, keep an eye out for me haha. s2 sliver C34 - plates QIKNLO - will be all over the joint visiting mates and might hit up panthers maccas at penoo on a thursday night for ol times sake ahha.
nice work dude!
linky?
http://j-spec.com.au...EA-1647915.html
One owner
Front and rear cameras
Factory navi
Intelligent key & Immobiliser
Xenon headlights
Twin sunroof
Power front seats (no leather... yet)
AWD
Front and rear spoilers
Cruise control (looks like the same one Leon was doing)
Possibly aftermarket intake (need engine bay pic to confirm)
Cold pack
LSD
lol, 'sif I was going to be without buying a Stagea for long.
Nice work Cam!
Its a little bit earlier than mine, looking at the VIN. Looks like the Nismo Axle back exhaust,
Front cameras! lol, knew the V35s had em, didn't think the stageas did. Maybe they'll spot the Roo's jumping out at ya!
Edited by PN-Mad
Hey Josie,
Its me!
I'm pretty sure I've only beeped once but the flutter is a HKS SSQBOV.
Rice to meet you.
I want your spoiler... haha! Every time you go past I always think to chase you down haha....
I might just wrap my spoiler and be lazy.
Should stop by one time and say hi.. I'm the one with the brindle bullmastiff at the park... Plus I have a huge Domo sticker on my car now that you won't miss :P
Nice work Cam!
Yeah, Nismo or Autech was my first thought, but wasn't sure.
Already got a set of Tomei rods comin' whistling.gif... although not sure if going turbo or high comp NA
Car is in fantastic condition (Krist reckons it is "as nice as you'll ever buy an M35") although it does have a fully-hektic Blitz pod on it.
Pretty happy :)
Pretty happy :)
Very nice mate
Spotted a blue Stagea which happened to be Zeke on seacombe rd yesterday got the thumps up and he got the horn coz I was busy turning the corner and changing gears lol
Haha tripped out ..turned to look right and bam Stag.. Was so half asleep lol
Staggy looked very clean !!
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
