What are the chances of two Lightning Yellow C34 S2 RS FOUR S's cresting the top of a sharp steep hill from opposite directions?
Well it happened this morning...WOOHOO!!!!!
Spotted a lightning yellow S2 C34 this morning on Gilbert Rd, Castle Hill this morning at 9:20 this morning. Flashes & waves all round!!!
That could be wolverine's wife, Gav. They live in that area and my sister used to see that car a lot when she was working nearby quite a few years ago.
That makes sense Nick, as I know Wolverine has an S aswell. I've seen it on Knox Rd, Woodcroft a while back too.....
Spotted a green S1 N/A basemodel (giggles) on Racecourse Rd, Hamilton while I was in Brisvegas last week. Took afew shots with my phone, but it was too dark. No rear wing, no privacy glass, hubcaps........
I thought I had the only N/A S1. It was a private import. The badge on the tailgate should read "25G". Mine is green but has a white bonnet and silver guards and is very beat up atm It has really dark glass and 17".. I don't drive it off the mountain but prefer the turbo S1 when going out.
Edited by 66yostagea
White M35 (lowered) heading south on Pacific Highway between Byron Bay & Ballina about 9:30 this morning. Was 'making time' like he was trying to get home from Easter holidays. You on here?
    • The powder coating came in at $250 EACH. The TRX rims got a coat of clearcoat on the outside only.
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
