Been a while since I spotted anything. But last night I spotted 3 Stags on my way home.
Marion Road heading northbound @ about 5:30pm, White S2 with Dayz Kit and black wheels.
Henley Beach road heading into the city @ 4:30pm, Silver 260RS with bronze TE37's.
Sturt Road heading towards Marion shopping centre @ 6:00pm, White S2 with heaps of stickers on the rear windscreen. Gave a wave.
Spotted a silver s2 C34 parked in a business' yard on Wentworth Avenue in Pendle Hill. Seen this same car in the same location plenty of times before, but it's usually parked on the street opposite that yard.
  • 3 weeks later...
Spotted a white NM35 on my way out to Windsor last night, and another white NM35 with full aero kut on mulgoa rd in Penrith this afternoon.
Both times I was in my daily slartmobile...
White C34. Followed him from Hurstbridge to the Ring Road. I was in a black Pulsar. I own the yellow C34 that you saw the other day.
Spotted a white M35 with an aero kit on eastlink frankston bound about 11amish? Was heading citybound and saw it just as it was passing me
Could have been me, I use eastlink a fair bit, but I am sure a few of us do.
Hay guys
Anyone know the name of the Sydney stagea club ??
Meet a guy the other night cursing around who had a really nice looking stag & forgot his name & the club name
I think it was drag ???
Had a white 180 & white legnum following him
( I was in a rush to get somewhere )
And so I missed the cruse that was on ,
& I'm full retard when it comes to the internets :-p
Any help on sydney wagon import clubs ??
Hay guys
Are you sure you don't mean nsw stagea club? You will need to jump on Facebook and search for it
Awesome
That's what I wanted to hear
Thanks again n hope to catch ya on one of these cruses or meets
The main groups full name is Nissan stagea naw owners club. Just to make sure you are adding the main one.
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
