Been a while since I spotted anything. But last night I spotted 3 Stags on my way home.
Marion Road heading northbound @ about 5:30pm, White S2 with Dayz Kit and black wheels.
Henley Beach road heading into the city @ 4:30pm, Silver 260RS with bronze TE37's.
Sturt Road heading towards Marion shopping centre @ 6:00pm, White S2 with heaps of stickers on the rear windscreen. Gave a wave.
Spotted a silver s2 C34 parked in a business' yard on Wentworth Avenue in Pendle Hill. Seen this same car in the same location plenty of times before, but it's usually parked on the street opposite that yard.
  • 3 weeks later...
Spotted a white NM35 on my way out to Windsor last night, and another white NM35 with full aero kut on mulgoa rd in Penrith this afternoon.
Both times I was in my daily slartmobile...
White C34. Followed him from Hurstbridge to the Ring Road. I was in a black Pulsar. I own the yellow C34 that you saw the other day.
Spotted a white M35 with an aero kit on eastlink frankston bound about 11amish? Was heading citybound and saw it just as it was passing me
Could have been me, I use eastlink a fair bit, but I am sure a few of us do.
Hay guys
Anyone know the name of the Sydney stagea club ??
Meet a guy the other night cursing around who had a really nice looking stag & forgot his name & the club name
I think it was drag ???
Had a white 180 & white legnum following him
( I was in a rush to get somewhere )
And so I missed the cruse that was on ,
& I'm full retard when it comes to the internets :-p
Any help on sydney wagon import clubs ??
Hay guys
Are you sure you don't mean nsw stagea club? You will need to jump on Facebook and search for it
Awesome
That's what I wanted to hear
Thanks again n hope to catch ya on one of these cruses or meets
The main groups full name is Nissan stagea naw owners club. Just to make sure you are adding the main one.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
