Every State has this exept for you guyz so here ya go.
This is a thread which we jjust tork complete crap about anything, just for the fun of it...
Lol i just noticed your signiture Cassi lol. So where is this mafia based?
  • Like 1
https://www.sau.com.au/forums/topic/54460-the-wasteland-act-style/
I'm down with the...errr...South-by-South-East...ummm.What would anyone classify Jerra' as?!Skylinegal!SxyGTST!Help me out on this one!I guess I'm a Southsider...even if Queensland is still in my blood!
queenslands still well and truely in my blood jayce! i miss my home land!!!
im kinda south central i guess you'd call it? weston anyway
I'm hearin' ya 'bout the Sunshine State!I'm getting misty-eyed just thinking about it...
South-Central,you say?Kinda Ice-T,dontcha think?!Word up,G.
LTSJayce: Jerra is roundabout eastish...more like a compound really!!!
All I can say is GO THE BRONCOS.......COME ON COWBOYS!!!!!!......THE MIGHTY MIGHTY LIONS.......AND THE QLD REDS WILL BEAT THE BRUMBIES NEXT YEAR!!!!!! (well at least one game!) so what state do I come from????? hahahaha
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
